What mods would you use to get a 500bhp 300zx?
Old Mar 3, 2002 | 11:43 PM
silvrhand's Avatar
Snazzy Title
Re: not true
Okay..
First off running 500hp on stock turbos would be pushing your efficiency and margin for error well below what I would ever consider safe for the engine.
To do it right and not have to run race gas on perfect conditions, and somewhat reliable I would definetly suggest a turbo upgrade.
You are still looking at around 15/20k to get everything done right and with quality parts. Can you do it ghetto style? Probably but would you really want to do that to your Z?
It's your call..
- john
Old Mar 4, 2002 | 09:34 AM
silvrhand's Avatar
Snazzy Title
Re: not true
Take a look at the things you would want to really run your car at that kind of power:
Turbo Kit (TD05-16G) would be my suggestion
Injectors
Intercoolers
ECU Upgrade
Boost controller
A/F controller
EGT Gauges
Intake
Exhaust
Test Pipes/Downpipes
Clutch
Brakes
Intake
Test and Tuning
You could do the parts for around 12k, then the odd and in stuff that you may need. By the time you are all said and done I could easily see 15k.
- john
Old Mar 5, 2002 | 05:36 AM
silvrhand's Avatar
Snazzy Title
Re: HP RANGE
Welp..
I would never consider NOS on my car, so I never include that as a mod. And yes it would be more than 500 rwhp, but if I was going to change my turbos the TD05-16G kit would be the only route I would go.
And with the 550 injectors you are max'd at about 550rwhp, which is about 650-700 at the flywheel..
- john
Old Apr 9, 2002 | 08:23 AM
silvrhand's Avatar
Snazzy Title
Re: What mods would you use to get a 500bhp 300zx?
George,
I wouldn't feel too comfortable running my stock turbos at more thatn 15psi, the data just isn't there for me to feel it's safe. I definetly would not run higher than 17psi, as most that have pushed 19psi the efficienty goes through the floor...
I'd rather do it within a safe error margin and add a new set of turbos, exhaust manifold, and other little goodies.
Nothing like porting and polishing everything when you pull the engine, I'd rather do it right the first time out the box then push your car a little hard and end up costing you more money in the long run.
Do it right, and you don't have to do it again..
- john
SPYCARRUSSELL
FS: 300ZX (90-96)
Aug 6, 2006 11:54 AM
boostedspra
Jun 5, 2006 10:14 AM
beeb_z
FS: 300ZX (90-96)
16
Dec 16, 2004 05:25 PM
mikecustoms
Sep 17, 2003 01:06 PM
GodZilla
May 23, 2002 11:06 AM
