what is that from ??
RE Running rich
My '90 NA had the same problem. Here's what I did:
(1) New platinum plugs
(2) New air filters
(3) Changed the oil (Yep... that finally got it through... it gets contaminated and causes the hydrocarbon emissions to be high)
I also discovered later I had a defective throttle position sensor... which I'm sure affected the emissions too.
Keep your idle up to around 2 or 3 thousand while you're waiting to get your test... that helps keep the cylinders cleared out.
Hope this helps,
Johann
(2) New air filters
Hope this helps,
Johann
