what is that from ??
Old Oct 30, 2003 | 08:31 AM
Z Car Barbie's Avatar
User Friendly
Usually that is caused by a bad O2 sensor.
Old Oct 31, 2003 | 05:59 PM
JohannB's Avatar
RE Running rich
My '90 NA had the same problem. Here's what I did:
(1) New platinum plugs
(2) New air filters
(3) Changed the oil (Yep... that finally got it through... it gets contaminated and causes the hydrocarbon emissions to be high)
I also discovered later I had a defective throttle position sensor... which I'm sure affected the emissions too.
Keep your idle up to around 2 or 3 thousand while you're waiting to get your test... that helps keep the cylinders cleared out.
Hope this helps,
Johann
