weird problem
Old Jun 2, 2004 | 03:13 PM
Riz Z Speed's Avatar
Administrative Brown Guy
there's like so many things it could be.
pull your plugs, check em.
check your timing and crank angle sensor.
Did you do a 60K recently?
Fuel pressure regulator and fuel dampner could also be checked.
fuel injectors?
Old Jun 2, 2004 | 07:47 PM
craZed's Avatar
reset your ecu
Old Jun 3, 2004 | 12:23 AM
OrangeZ32's Avatar
well my buddy had the same kinda problem, but completly different car. But an engine is an engine. He had no compression in 2 of his clyinders, so his 3000GT V6 became a 3000GT V4 . We'll we never figured out the problem and he sold it i know it doesn't help much but, check your compression cause he was running really rich and sometimes he'd be alright, other times he'd be bad, than eventually it was bad for good. To sum it all up, check your car's compression, cause if your experiencing a loss of power maybe it's cause your clyinder isn't firing, check ur plugs as Rizz said. Check your ECU, might have just been a bit of a flop or something. Ive reset ECU's on few cars with wacky problems that i couldn't figure out, than they were A-okay. So try resetting your ECU, than start going down the list of things rizz said, but a compression test is quick and you can do it while your checking your plugs. But, if it's your plugs, have fun cause plugs are never ever fun to work on, so cross your fingers and hope that doesn't happen. Better yet run by an autozone and ask if they'll hook your car up to the computer to see what readings they get out. All of the ones I've gone to have always done it for free but i think they're supposed to charge like 13 bucks, so give that a go, and that will give you something to work with.
Old Jun 3, 2004 | 04:41 PM
checking for ecu codes is a good idea.
unless the local parts store has a Nissan Consult they won't be able to read your codes cuz the car is an OBD I system. All 95+ cars are OBD II which can easily be read by aftermarket code readers.
http://www.ttzd.com/tech/diagnostictech.html
go there for ecu diagnostics.
a compression test is a good idea however. The process for that is explained in the online service manual. First link after FAQ in my link page.
Jennings.brent6
May 30, 2014 11:10 PM
1996z32
Jun 23, 2012 11:18 PM
MadZ420
24
Mar 7, 2009 10:05 AM
zeppelinboy
May 5, 2007 03:21 PM
Carl's Z
Mar 3, 2007 07:41 AM
