Water/Alcohol Injection
What can anyone tell me about Water/Alcohol Injection, and water/alcohol/hydrogen peroxide injection? I know that it has been used on military planes since WWII with escellent results. Anyone have any experience with this?
I have been reading about it and claims of 20 - 30% increase in power without danger of damage to the engine. Also, allegedly a bonus is much lower emissions. This all sounds plausible from a scientific angle... but it also sounds too good to be true. Johann B |
it's possible and it's true.
The secret is in the delivery. Super fine mist of water helps lower emissions, lowers overall cylinder temperatures and increases combustion which equals more power. Alcohol I wouldn't recommend since it's already in a lot of the gas we use, so you'll just further dilute your gas mix. Even though hydrogen peroxide is a great accelarant, I haven't heard of anyone using it in their cars. |
Google ...... "water injection kit"
Methanol looks good to me. |
The secret is in the delivery. Super fine mist of water helps lower emissions, lowers overall cylinder temperatures and increases combustion which equals more power. Alcohol I wouldn't recommend since it's already in a lot of the gas we use, so you'll just further dilute your gas mix. Even though hydrogen peroxide is a great accelarant, I haven't heard of anyone using it in their cars. Thanks for the replies. I found a lot of info on the web. I just wondered if anyone here had actually had any first hand experience with it. I might try it later. First I have to get this damn thing to pass emissions again. I'm gonna try adding some denatured alcohol to the fuel. I have read several articles claiming that it will work. Thanks, Johann B |
I know Aqua Mist helps for the TT cars. It helps cool the incoming air to the engine.
I would only assume that it would work on an NA car but not sure to what extent. |
Kyle,
Thanks for the reply. From what I have read, it works in the NA engines too, but with smaller gains. I also found a really interesting reprint from WWII on the web about water/alcohol injection on aircraft engines. It showed several graphs detailing performance gains. The only thing I don't get is why this isn't used on cars and other vehicles today. It seems like a very inexpensive way to gain power, and at the same time lessen polution. I saw a segment of the TV show 'Trucks!' on propane injection. Seems there's plenty of ways to boost power without dropping a bundle and without going into the engine. Johann B
your welcome,
A buddy of mine had a propane injected truck it seemed to work realy well the downsize was the size of the tank he needed in the bed of te truck.. I had started doing some research a while back on how to cool the intake temp and a few other items. It seems thats the basic thing you are doing with aquamist or water injection. The item I could not find that I wanted to find was what the optimal air intake temp would be to achieve the maximum amount of HP.. |
STI's come with aqua mist for cooling, and i am in proccess of making my own for a wrx....it's gonna cost me about $30 total.....pretty inexpensive way to cool your engine down which we all know results in more power
