91zxtt |
01-12-2004 11:26 PM |
I don't know about the Z32 having this, but I had a Z31 that had a low coolant level warning. Check the coolant. I'm not sure if the Japanese had different warnings signals. I've never seen that one on mine, but I haven't seen the coolant warning either. It would be a cheap science experiment to try running premium unleaded. Does the car ping? Have you noticed poor mileage? If you stand behind the car with it running in a semi-enclosed area, do your eyes begin to burn? If you answered yes to any of these, you could have an air/fuel ratio problem. This could cause the exhaust temp to increase, if that is what the warning light is. Check the coolant and try better gas, then see what happens.
