upper cabin air aspirator
Old Dec 18, 2003 | 07:36 AM
typeaproduction's Avatar
the upper fan has been making scratchy squeeking sounds for a while, ive taken it off and tried to lubricate, but the screws are not going to lossen up, and its also very hard becase of the little screws and having to use a smallllll screw driver makes it 5x harder to turn, anyway, i took the fan out, what excatly is this going to do? just mess the automatic temp. control up? is anything else caused because of this? thanks a lot for anyone help
Old Dec 18, 2003 | 10:14 PM
Riz Z Speed's Avatar
Administrative Brown Guy
yep pretty much. Your climate controls won't work properly if that sensor isn't receiving a constant air flow to check the temp. You should try to fix it if you want your climate controls to function properly.
http://www.twinturbo.net/ttnetfaq/FAQpages/tempfan.html
http://www.aus300zxclub.com/tech/acfan.htm
These two links should help you out on fixing the problem provided you didn't already destroy the fan and parts within.
beg3yrs
Sep 22, 2014 06:17 PM
Old Codger
Apr 25, 2014 04:52 AM
nightfur
Jan 30, 2012 07:35 AM
BhamZ1982
Aug 10, 2007 01:53 PM
pearly whites
Jan 4, 2004 04:10 PM
