Timing and ECU questions
Old May 8, 2012 | 10:55 PM
PleaForPurge's Avatar
This may be a stupid question, but when my crankshaft pulley is at 0 degrees, the dimples and notches of my cam gears should be lined up with the dots on the plate behind them, correct? My Z is a whole tooth clockwise from those dots when the crankshaft pulley is at 0.
Also, when I looked up the numbers from my ECU it came up as a turbo 300ZX auto trans ECU. Mine is a standard transmission. When you are checking codes on your ECU, does the screw spin a few times around before it stops? Mine seems to keep spinning and never stops. I've been looking at ECU's and I found a few for a turbo standard trans in the $200-$250 range. Does anyone recommend I get a new one because my screw spins around endlessly and it's for an auto trans? Does it even matter that it's for an auto trans?
Old May 9, 2012 | 02:12 PM
Rupe's Avatar
Horsepower Mathematician
Does the ECU spit out the codes if you turn the screw according to proper procedure?
Old May 9, 2012 | 06:46 PM
If I try to turn the screw, it seems to spin around endlessly in each direction and the LED never flashes or does anything besides stay solid
Old May 10, 2012 | 10:23 AM
Rupe's Avatar
That part was well understood, but are you following the right steps in turning it?
Old May 10, 2012 | 01:28 PM
Yes I am. I'm following this write up:
How to check the codes of the ECU in a '90-'95 Nissan 300ZX
Doomfinger
Jul 26, 2012 09:09 PM
mikesz
Jul 10, 2010 11:41 AM
captken
Sep 25, 2009 07:43 PM
Phyxius
Sep 19, 2004 12:38 AM
toletero
Jun 19, 2002 06:46 AM
