ZDriver.com
-   300ZX (Z32) Performance / Technical (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/)
-   -   Starts but cant hold idle (https://www.zdriver.com/forums/300zx-z32-performance-technical-47/starts-but-cant-hold-idle-30461/)
Lanoi Apr 7, 2010 11:45 PM
Well cam seals are in and no leaky oil. now i can start the car but it cant idle.
when i start it up, it starts fine. trys to idle for a brief second or two, and the rpms gos down to the point which it stalls. I have check for disconnected or crack vaccum lines. TPU, i think it may be the MAF not sure. i dont have a spare one to try out. any advice about MAF or other things i may have looked over.
ZLover4Life Apr 7, 2010 11:58 PM
Sounds like a massive air leak (not a small vacuum hose leak)... check your intake pipes to make sure they are all on properly.
MAFs don't generally go bad for no reason. Also check the connectors on the rear driver's side of the plenum (one is the IACV).
Lanoi Apr 8, 2010 12:24 AM
idle air control valve i try adjusting thwe screw in and i pretty much did the same thing but when the rpms go down low to where it should stall it jumps up then stalls
ZLover4Life Apr 8, 2010 12:34 AM
How low do you think it's supposed to go? Z32s should idle around 800rpm. (And generally, you shouldn't mess with that until it's running healthily... you may have just added to the problems later on.)
Lanoi Apr 8, 2010 12:44 AM
i was thinkng around 750 range up or down a bit . massive air leak huh .
Lanoi Apr 8, 2010 12:45 AM
i dont hear much of anything like air noises
ZLover4Life Apr 8, 2010 12:52 AM
Spec is actually 750 to 850, but I generally aim for closer to 850 so it's a little smoother.
... and of course you can't hear air leaks, the car is dying. lol
Check all your electrical connections to be thorough.
I don't recall, are we talking TT or NA?
Lanoi Apr 8, 2010 01:11 AM
i have n/a
KasbeKZ Apr 8, 2010 08:00 AM
it could be a fuel pressure problem. hook a gauge up, look for a drop after it primes, pinch the return line ext. that'll let you know if it's a fuel problem.
as for the maf.. just unplug it. if the problem persists, it's not the maf.
Lanoi Apr 8, 2010 02:10 PM
its the MAF i just clean it out and car runs and idles now
KasbeKZ Apr 8, 2010 02:14 PM
wow... that goes against so many threads that i've read saying that the maf doesn't affect idle.
Lanoi Apr 9, 2010 10:53 AM
yea most the treads ive read say vaccum hose or AIC , but it was easy to clean with the MAF cleaner from a bottle took like 5-10 mins.
