Squealing noise when starting
Hi everyone, new to the forum. I'll most likely be buying my Z32 tomorrow night and I wanted to get started on my car research. My first question is about a strange squealing noise that appears just after starting the car. To me, it sounds like some kind of belt that's making noise because the car isn't driven much but I could be wrong. The noise disappears shortly after initial start up and doesn't occur while driving. Anyone know the cause of this?
Welcome to ZDriver! :006:
Without actually hearing it, and by going by your description of "squeal"... I'd say an accessory belt, or starter. Take a flashlight and some basic tools, and do a lil digging... |
(Post 296697)
You have a loose accessory belt. Tighten them. There should be less than a half-inch or so of deflection if you push on them.
If that doesn't do it, look into belt dressing - it's a spray that will quiet it. |
(Post 296702)
Every belt-driven accessory on the VG30 has a tension adjustment bolt. Figure out which belt, follow it to that accessory, find the bolt on the accessory bracket that pivots the accessory in/out... can't really describe it better without coming over and holding your hand...
(Post 296811)
| All times are GMT -7. The time now is 05:50 AM. |
