Screeching Belt or bearing? Need help (Video)
Old Nov 22, 2011 | 03:24 PM
tennisman93's Avatar
Hey guys i have a 91 N/A it just started to make this noise the other day it started out just a very sleight chirping noise then got louder to what it is now i haven't drove it in 2 days i have tighten the alternator belt which is the one thats making the noise and it did nothing. when i spray this belt stuff on it it stops immediately then comes back after a few seconds.. so idk if i should replace the belt or if its not the belt also been told it could be the pully idk. here is a video of the noise i can take more if needed thanks.
http://youtu.be/b-JaKCalEng
Old Nov 24, 2011 | 10:04 PM
lowkeyz's Avatar
for what belts cost just replace em. use factory belts they seem to be higher quality than aftermarket.
Old Nov 24, 2011 | 11:56 PM
Cheap belts are harder and dont realy deform when they contact the pulley. FSM has the belt tightening procedure, it's supposed to be alot tighter then most think.
Old Nov 26, 2011 | 09:43 PM
Alright i ended up changing the belts and the alt and the problem is almost gone but now somthing is just cherping almost like awhistle when i accelerate coming from the same area.. any ideas on that?
Old Nov 28, 2011 | 01:31 PM
trailerbred's Avatar
when you had your alternator belt off did you check the bearings on the alternator pully, i had to replace my alternator because the pully bearings wore out not sure if thats your problem, but it definitely happens
Old Nov 28, 2011 | 04:20 PM
the alt is brand new i replaced the whole thing thats what i was told it was in the first place..
280z dude
Feb 5, 2015 06:57 PM
WanganDevilZ
Aug 27, 2012 06:44 PM
NateB
Jan 3, 2006 07:03 AM
G00DHUM0R
Nov 20, 2002 08:03 PM
rngrck
Apr 24, 2002 10:48 PM
