Replacing Clutch
Old Aug 6, 2005 | 09:14 PM
b300z's Avatar
caught the z fever
Replacing Clutch
I started tearing out parts to get ready to put my new clutch and lightweight flywheel and other goodies today.
i was able to get everything out pretty easily to my surprise...test pipes, x-pipe, driveshaft(yes its a 1 piece 91 ), starter, slave cylinder, the big ole tranny, clutch, and flywheel.
after looking at the disc, i guess the problem i am having is not my clutch. there is still a fair amount of material on the disc. but at the least, now i know i shouldnt have a problem with my clutch for a long time.
i ran into a problem with my lightweight flywheel, and i wont be able to get it worked on until monday. since it is used(got it from z_wrecker) i am getting it resurfaced, but there were no machinging shops open today dammit.
does that even look worn??? im such a freakin idiot. is that a stock clutch?
91...here is the proof of my 1 piece driveshaft...now what brand is it?
Old Aug 6, 2005 | 09:38 PM
b300z's Avatar
caught the z fever
oh yea...i forgot to say...thats an RPS 6 puck spring hub clutch. long story...i wanted to get the ACT street clutch, but TSP didnt have it or the RPS street clutch in stock i guess, so they reccommended this 6 puck one. They had pretty good service. I was a bit shakey at times, because it took like 4 days longer than what they said
Old Aug 7, 2005 | 08:32 AM
CanyonCarver's Avatar
Jack Of All Trades
Make sure and replace that rear main seal..
That old clutch has seen some heat........ eh
Old Aug 7, 2005 | 03:49 PM
91zxtt's Avatar
On the driveshaft,...I'd say Z1.
You'll want to change the rear tranny seal as well.
I thought that the 6-puck were notorious for harsh engagement. You may also want to look into a pilot roller bearing to replace the pilot bushing. IMO, it's better.
Old Aug 7, 2005 | 04:19 PM
b300z's Avatar
caught the z fever
crap...i forgot about the rear tranny seal
i already have the rear main seal and NISMO roller bearing pilot bushing....along with the upgraded clutch pivot ball, SS clutch line, and shifter bushingsin the pic....
im gonna start working on those and the clutch line tonight
91, i thought that too, and i told my dad that, and he said that the guy said it will be a bit harsher, but shouldnt be too bad because its a spring hub
Old Aug 7, 2005 | 06:32 PM
b300z's Avatar
caught the z fever
some more work i did today...decided to take off the calipers and rotors and repaint them since i wont be getting new calipers and putting on my new rotors anytime soon.
which connection on the tranny is for the back-up lights?
pics...
some before pics...
Old Aug 7, 2005 | 06:34 PM
b300z's Avatar
caught the z fever
replaced...
cleanup...
my favorite pic of the day...
Old Aug 7, 2005 | 09:19 PM
Jack Of All Trades
you're still a brave soul to put stands under that radiator support......
Old Aug 8, 2005 | 12:15 PM
b300z's Avatar
caught the z fever
yea, my dad was the one who jacked it up and put the stands there
i told him what you guys said, and he just said "no, no it will be fine. its on the brackets anyway"
anyways...went to the machine shop today flywheel will be done tonight/tommorrow
when i asked him about the new release bearing, he said it was too big to fit onto that piece. was i supposed to get a new one of those, or was there a mistake made somewhere?
Old Aug 9, 2005 | 07:54 AM
b300z's Avatar
caught the z fever
any info would be greatly appreciated
Old Aug 9, 2005 | 08:20 AM
91zxtt's Avatar
That is definitely a part that should be replaced. They probably shipped the wrong bearing. Actually, the old one looks kinda small. From what I remember, the 'throw-out' bearing on mine was closer to the same size as your new one. Maybe there's a difference between the TT and N/A and they sent you the TT one by mistake.
Also, looking at the pictures that show your test pipes, it is very clear that the N/A and TT test pipes are not the same as previously stated by [banned member]. I recall reading that and thinking that his statement made sense. He said that the N/A headers cover the same route that the TT manifold+turbo+DO's do. Well, they don't, so he was wrong,...again,...shocker.
Old Aug 9, 2005 | 09:11 AM
entropy31's Avatar
The Cake Is A Lie!
a bit off topic (sorry) i want to test my car identification skills. thats an xjs next to you in the garage, right b.
Old Aug 9, 2005 | 09:44 AM
b300z's Avatar
caught the z fever
yup...96
i went to courtesy to check on if there was a difference in release(throwout) bearings, and it is the same as my new one and says it will fit all 90-96 Zs
i also looked to see if i could buy that other part, but its not on there.
so now i am completely confused...
im gonna have the machine shop guy take off the current bearing and then check up on it again
dammit i wish skully woulda taken pics
Old Aug 9, 2005 | 10:51 AM
b300z's Avatar
caught the z fever
new problems...
i got bearing off of that piece, and i guess it fits, but which way is it supposed to go in?
also, the flywheel could not be resurfaced...the guy couldnt get the plugs out
could i resurface it myself with a lot of sandpaper and steel wool
<----EDIT: 1000 posts!!yay!!
Old Aug 9, 2005 | 11:29 AM
b300z's Avatar
caught the z fever
heres some pics of the lightweight one that cant be resurfaced...
does it HAVE to be resurfaced? dammit, ive been wanting to put this in for over a year now too...
finished my front calipers and rotors...
Old Aug 9, 2005 | 06:00 PM
b300z's Avatar
caught the z fever
this is beginning to look like skully's thread....
but anyways, another problem...my dad got the roller bearing pilot bushing in and now the bearing is not turning. so i guess that piece is shot and i will have to put in the crappy one? *sigh* dammit
Old Aug 13, 2005 | 04:43 PM
b300z's Avatar
caught the z fever
well, i ended up putting the other one in, and it fit perfectly
everything is done, now all i have to do is lower the pedal a little bit cuz it is releasing at the very end of travel.
here are some more pics
front tranny seal...replaced
rear main seal and pilot bushing in
Old Aug 13, 2005 | 04:47 PM
b300z's Avatar
caught the z fever
did a little cleaning first...
it took us 4 tries and a big boot to get the tranny all the way on. we struggled with it for a while. my dad and i had got it all the way up to the flywheel and then it just stopped. a neighbor came over and we moved it around a bit and he kicked the back of the tranny a few times and it went in.
picturing a 1-piece driveshaft...dunno
a little problem that i found...is that gas?
Old Aug 13, 2005 | 04:49 PM
b300z's Avatar
caught the z fever
i also installed the GD subframe spacers...finally
after shots of calpiers and rotors
i also have a vid of the car with just headers to make sure the car starts fine before we put everything else back in...
http://www.putfile.com/media.php?n=MOV0008060
Old Aug 13, 2005 | 05:58 PM
91zxtt's Avatar
Yes, that is gas. Remove that heat shield so you can have a btter look at it. There are a couple rubber fuel lines that connect to the hard lines behind that heat shield.
Also, fix your tranny mount....you've got a busted exhaust hanger.
Remove your AIV's. It's easy and it'll save you approximately 15 lbs.
Old Aug 13, 2005 | 07:12 PM
b300z's Avatar
caught the z fever
if i have an exhaust hanger by the tranny mount, then its not getting used
can i remove my aivs if i dont have an upgraded ecu?
i definately need to do that since air is still going through and making my car sound like it has a BOV when i shift @ 2k rpms
ok...got 70 miles on it today
it definately grabs. not as bad as i thought it would be, but definately different.
im kinda worried tho...when i let my foot off the clutch in first to and started moving, it shook pretty hard
is that me not being used to the different engagement, or is something wrong?
my dad said it is just doing that because it is getting broken in
Old Aug 13, 2005 | 09:13 PM
bardabe's Avatar
Bad Speller
well it's a 6 puck. get use to it. they never have smooth engagement. 6 pucks ahve great grip but nothign smooth about them.
Old Aug 14, 2005 | 05:26 AM
Jack Of All Trades
good pics and info.
Old Aug 14, 2005 | 06:29 AM
DanZ32's Avatar
Dan's the Man
Good work b. Get back under there and figure out that fuel leak pronto.
Old Aug 14, 2005 | 09:40 AM
b300z's Avatar
caught the z fever
i know its not gonna have smooth engagement, but im still a little worried about how much it was shaking.
im hopin to get another 100 miles on it today and see what progress i have
again...forgot to say earlier....the clutch pedal isnt very stiff at all. it feels more like a stock clutch than an aftermarket one. could the SS clutch line be causing this?
will i notice a difference when it is broken in? i think im only gonna go like 300 miles until i let it loose. ive only got 5 more days with my fairlady until i go to college, and i want to take it on one last long ride before i go. all of my driving has been in town, so ive been doing a lot of stopping and starting
