Price list.
Old Jan 20, 2004 | 07:34 PM
NISMO LMR's Avatar
Price list.
Ok guys, time to help out the lanky guy here. I made the list myself, including product, address, price, and code number. Now I know this list is long as hizzell, but scroll through, and if u see a better price than listed, gimme a shout! Best prices i've found:
Courtesyparts.com
-Battery mounting kit
http://www.courtesyparts.com/Merchan...de=Z32BT-MNTKT
$11.03
Code:Z32BT-MNTKT
-Battery mounting tray
http://www.courtesyparts.com/Merchan...de=24429-BTRAY
$17.52
Code: 24429-BTRAY
-Exterior moldings
http://courtesyparts.com/z32/oe_mouldings.html
-Cowl
http://courtesyparts.com/z32/oe_cowls.html
-EGR Valve (Exhaust Gas Recirculation)
http://www.courtesyparts.com/Merchan...y_Code=z32-egr
$98.51
Code:14710-Z32AT
-Temperature sensor gauge
http://www.courtesyparts.com/Merchan...de=25080-TPGSR
$14.22
Code: 25080-TPGSR
-Engine coolant Temp sensor
http://www.courtesyparts.com/Merchan...Code=22630-Z32
$21.51
Code: 22630-Z32
-Frontal by-pass water hoses
http://www.courtesyparts.com/Merchan...de=14055-00002
$6.36
Code: 14055-00002
-Thermostat
http://www.courtesyparts.com/Merchan...de=21200-00001
$10.04
Code: 21200-00001
-Alternator - Remanufactured
http://courtesyparts.com/Merchant2/m...de=23100-00002
$289.41
Code: 23100-00002
-Main wiring harness main clip
http://www.courtesyparts.com/Merchan...Code=MNHRN-CLP
$1.70
Code: MNHRN-CLP
-Ignition coil
http://www.courtesyparts.com/Merchan...de=22448-00000
$53.65
Code: 22448-00000
-Ignition coil repair harness (Set of 4 connectors)
http://courtesyparts.com/Merchant2/m...de=24079-00001
$58.54
Code: 24079-00001
-Oil pressure switch
http://courtesyparts.com/Merchant2/m...de=25070-00001
$63.14
Code: 25070-00001
-O2 sensor - Passenger
http://courtesyparts.com/Merchant2/m...de=22690-00001
$61.85
Code: 22690-00001
-O2 sensor - Driver
http://courtesyparts.com/Merchant2/m...de=22690-00002
$114.91
Code: 22690-00002
-Knock sensor
http://courtesyparts.com/Merchant2/m...de=22060-00001
$141.77
Code: 22060-00001
-Knock sensor with harness
http://courtesyparts.com/Merchant2/m...Code=22060-Z32
$166.42
Code: 22060-Z32
-Head bolt set
http://courtesyparts.com/Merchant2/m...Code=Z32-11056
$56.39
Code: 11056-Z3200
-EGR valve gasket
http://courtesyparts.com/Merchant2/m...de=14719-Z3200
$3.40
Code: 14719-Z3200
-Engine gasket set
http://courtesyparts.com/Merchant2/m...de=10101-00001
$277.40
Code: 10101-00001
-Head gasket set
http://courtesyparts.com/Merchant2/m...de=11042-00001
$215.95
Code: 11042-00001
-Head gasket (1) http://courtesyparts.com/Merchant2/m...de=11044-00001
$46.89
Code: 11044-00001
-Valve cover gasket - LH (intake cam)
http://courtesyparts.com/Merchant2/m...de=13270-00001
$12.31
Code: 13270-00001
-Valve cover gasket - RH (passenger side)
http://courtesyparts.com/Merchant2/m...de=13270-00002
$12.31
Code: 13270-00002
- Plenum intake gasket
http://www.courtesyparts.com/Merchan...de=14033-Z32PG
$6.65
Code: 14033-Z32PG
- Upper Insulator injector
http://www.courtesyparts.com/Merchan...de=16635-00003
$6.66
Code: 16635-00003
- Lower Insulator injector
http://www.courtesyparts.com/Merchan...de=16635-00004
$18.12
Code: 16635-00004
- Lower O ring seal
http://www.courtesyparts.com/Merchan...de=16618-00001
$14.28
Code: 16618-0001
- Lower O ring seal
http://www.courtesyparts.com/Merchan...de=16618-00002
$3.6
Code: 16618-00002
- Upper O ring seal
http://www.courtesyparts.com/Merchan...de=16618-00003
$2.88
Code: 16618-00003
- IAAC Gasket
http://www.courtesyparts.com/Merchan...de=23785-Z3200
$1.27
Code: 23785-Z3200
- Brake booster vacuum hose check valve
http://www.courtesyparts.com/Merchan...de=Z32BR-BVHCV
$18.59
Code: Z32BR-BVHCV
- PCV Valve
http://courtesyparts.com/Merchant2/m...de=11810-00002
$8.61
Code: 11810-00002
- NISMO radiator cap
http://www.courtesyparts.com/Merchan...de=21430-RS012
$29.14
Code: 21430-RS012
- Drink holder
http://courtesyparts.com/Merchant2/m..._Code=ZX9096PC
$29.95
Code: ZX9096PC
- Aluminum lower radiator hose
http://www.courtesyparts.com/Merchan...ode=Z32-LWHSKT
$79.00
Code: Z32-LWHSKT
SGPRACING.com
- JUN cam gear (Exhaust)
http://store.yahoo.com/sgpracing-sto...vg30dedex.html
$175.00
Code: JUN1006M-N104
- JUN cam gear (Intake)
http://store.yahoo.com/sgpracing-sto...vg30dedin.html
$175.00
Code: JUN006M-N004
- 60,000 service kit
http://store.yahoo.com/sgpracing-sto...03060ksek.html
$280.00
Code:NIS60K
- Underdrive pulley
http://store.yahoo.com/sgpracing-sto...i30ttunpu.html
$160.00
Code:ASP39200
- O2 sensor
http://store.yahoo.com/sgpracing-store/ni9030o2se.html
$60.00
Code: NIS02
- Coolant sensor
http://store.yahoo.com/sgpracing-store/ni9030cose.html
$20.00
Code: NISCOOLSENSOR
CONCEPTZPERFORMANCE.com
- EFI wiring harness
http://conceptzperformance.com/Cart/...hp?II=293&UID=
$300
Code: NIS300-B4011
- NISMO thermostat
http://conceptzperformance.com/Cart/...74664.12.96.77
$79.99
Code:300-RS580
- NISMO fuel filler cap
$59.99
Code: 300-FC
- NISMO oil filler cap
$87.99
Code: 300-OFC
- STILLEN battery tie down
$39.95
Code: 300-102020
Any ideas???? Peace foo's
Old Jan 20, 2004 | 07:39 PM
NISMO LMR's Avatar
OOoo and one more thing.
When replacing the EFI wire harness... How do I do it? Any diagrams? Peace foo's
Old Jan 20, 2004 | 09:06 PM
emo236's Avatar
confuzed member
On all the the stuff you're getting from courtesy, call Coz on it. there's a lot of things not on their website that they have. pretty much any OEM part. Give em a call and see if they give you cheaper prices...they probably will on a few things.
Old Jan 21, 2004 | 01:12 PM
NISMO LMR's Avatar
WTF's Coz? Peace foo's
Old Jan 21, 2004 | 02:05 PM
emo236's Avatar
confuzed member
Concept Z performance...sorry.
Old Jan 21, 2004 | 07:49 PM
NISMO LMR's Avatar
O ok man, thanks, peace foo's
Old Jan 21, 2004 | 09:55 PM
91zxtt's Avatar
Nismo, Do you have a little spare time on your hands? You listed everything on the internet. How could we find a better price? You listed it all.
Old Jan 22, 2004 | 02:08 PM
Riz Z Speed's Avatar
Administrative Brown Guy
What?
No kitchen sink?
Old Jan 22, 2004 | 03:28 PM
NISMO LMR's Avatar
Yea I was thinking about that, be kinda nice to have in the back, but I decided against it. Haha, God I cant wait to get me Slicktop! Haha
Old Jan 22, 2004 | 11:02 PM
Patience has never really been a young mans virtue.
Old Jan 24, 2004 | 11:33 AM
NISMO LMR's Avatar
O man I have plenty of pateince... Like sometimes when ever im at my GF's house it takes FOREVER to... Never mind. Haha just messing. Or wait was it at her house or in the Wal-Mart parking lot? Haha (Remember that story Riz? ) But I spoke with RJ with D... something (D1 maybe?) drifters up in Buffalo, and he has basically changed my mind about getting rid of Redbird, even though its still kinda up in the air. He has a wrecked 92 NA 2 seater red (wrecked in back) that has good engine, so hes ripping out the heads for me, gas door, visors, misc. parts, and two nice leather seats (black)! All for VERY cheap (HENCE: Were selling his whole crew 3 RB20DET, 1 RB25DET, and 1 CA18DET, that is a $12,075 order, and were giving him a deal, so he kinda owes me I guess) So maybe I will keep her after all... But in the back of my mind it still doesnt make much sense to do so... O well, Peace foo's - Veritas
Old Jan 24, 2004 | 03:33 PM
Z_WRECKER's Avatar
thats great news Nismo...its just there is something special about your first Z, no matter what goes wrong you stay optimistic, and then you fly into a hairpin turn at 5 am after a hard night of party, and there is some gravel on the road+ cypress hill blasting, and before you know it your car is totaled and you are standing there without a scratch, and cd player is still running....hahahaha....i love Z's
Old Jan 24, 2004 | 04:23 PM
emo236's Avatar
confuzed member
Yea, Nismo...that's pretty sweet. Think about it. When Redbird is done....it will be YOUR car. You built it...you restored it...no one else.
Old Jan 24, 2004 | 04:24 PM
emo236's Avatar
confuzed member
And Nismo..I love the new sig.
Old Jan 24, 2004 | 07:42 PM
NISMO LMR's Avatar
Haha, yea i've become more optimistic about it lately... SCREW what everyone else thinks, Its my car. Im trying to import some images, but my cave man mind cant figure it out... Haha, HP's suck anways, I need to get em on my Mac G4 somehow. But i've figured out my pricing for the next few months:
Heads - $125
Timing belt - $45
Tubing - $35
New T-tops - $50
Leather seats - $35 a POP!
Miscellanious exterior/interior parts - $50
New clear coat - $90
50% tint job - $65
Im getting hooked up on ALLL of this crap. But lately i've been pondering just keeping the Z. I hope it pans out so I can. Peace foo's (by the way, yea my sig kicks ****! Haha later guys)
Old Jan 24, 2004 | 07:48 PM
emo236's Avatar
confuzed member
You weren't kidding when you said that this guy is giving you some good deals! $35 a pop for seats?! To post pics...just go to attach file at the bottom of the reply box and hit browse. Find your pic...double click on it and you're good as long as it isn't too big. I'd like to see some pics of the infamous redbird!
Old Jan 24, 2004 | 08:26 PM
emo236's Avatar
confuzed member
Hey for some other factory parts that you might need...it might be beneficial for you to go find a local Z club and join them. Not only will you have some help and some fun, but dealerships will give you the same discount that they give to shops...20%. Most clubs are free as well. Just an idea I had for you. If you're already in a club...go talk to someone in the parts department.
Old Jan 24, 2004 | 08:32 PM
NISMO LMR's Avatar
Good idea, never heard of that before. My problem isnt loading them on the site, its importing them onto the comp. I think the pics are misleading, haha. Redbird looks SICK AS HELL in the pics, then you see it in real life... Woah, what a change, haha. Peace foo's
Old Jan 24, 2004 | 08:33 PM
NISMO LMR's Avatar
O yea, and this guy is REEEAAALLLY hooking it up. Hes really helping me out, I guess he digs my situation maybe... O well, im getting my parts so its cool. Haha, peace foo's
Old Jan 24, 2004 | 08:40 PM
Z_WRECKER's Avatar
that is cool nismo that you are getting those parts for cheap....you deserve it i am sure you dropped a lot of time and money into your z, so this is like a little deserved prize you get
Old Jan 24, 2004 | 08:47 PM
NISMO LMR's Avatar
Yea I guess thats a good way of looking at it. I may keep Redbird after all... But now I have to take my damn hedgehog to the vet monday because he has another rash on his stomach... DAMNIT, there goes my clear coat fund! Haha, peace foo's
Old Jan 24, 2004 | 08:53 PM
emo236's Avatar
confuzed member
Importing them onto your CPU? You must mean from your camera. I'm guessing it should be via usb..maybe? And yea...post the picks up anyway.
Old Jan 24, 2004 | 08:59 PM
Z_WRECKER's Avatar
man i have a couple of geckos.... i love animals....for crying out loud my puppy is named Z....hope your hedgehog is ok
Old Jan 24, 2004 | 09:08 PM
NISMO LMR's Avatar
Haha, thanks dude. I love animals too, not an animal rights activist or anything, but theyre cool. I got a Bermise Python named ZOSO (after the Led Zep album cover) an Eastern King snake named Zappa after the great Frank Zappa, and my hedgehog named Hogie... Due to the fact that he resembles a hogie roll, haha. Peace foo's
Old Jan 24, 2004 | 09:22 PM
emo236's Avatar
confuzed member
errr...I have a dog and I used to have a pet spider named *****..well, he wan't really a pet, but he lived in the tree outside my house. He was this huge tree spider. It was fun b/c I could tell everyone that my ***** is HUGE!
