Overheating TT: Electric fan or headgasket?
Old Apr 17, 2004 | 12:09 AM
Riz Z Speed's Avatar
Administrative Brown Guy
Well you could go either way with this one. If you go with the proper sized electric fan, you free up hp by getting rid of the rotational mass that is the stock fan. But most electric fans (unless you use two) won't measure up to the stock one. You're going to want to get close to the stock cfm output which is about 3700 or so. If you can fit two electric fans in there that can combine to close to that number you should be fine.
Or go back to the stock fan by fixing the fan clutch and keep the car cool.
Old Apr 19, 2004 | 09:52 PM
91zxtt's Avatar
If you have coolant leaking into the oil, then your oil should have a milky consistency to it and it should froth up (kind of like milk). Check your compression. Are you getting any white smoke out of the exhaust, or does the exhaust smell sweet? Those Z dipsticks are useless. It's almost impossible to read them accurately.
Monkies
Feb 7, 2011 02:03 PM
duowing
Oct 15, 2007 02:39 PM
HybridS130
Sep 6, 2006 02:33 PM
Skip81ZX
Mar 25, 2002 02:24 AM
