Need some help fella's
Old May 10, 2005 | 05:56 PM
z32gizzle's Avatar
Well as some of you know I got hit by a El Camino now it was mostly cosmetics damage but I started the Z up today and It bogged out then It would rev automatically and then stop but at like 2,500 to 3,000 rpms it would act almost like it wasnt getting enough fuel...but It was fine before I took off my front bumper... I hooked the MAF back up just in case but it would work and now it wont start..any ideas? The only thing I really gotta ask is I drove it for a good 2-4 miles after it was wrecked seeing only cosmetic damage and nothing sounded horrible or anything drove perfect but when i unhook my MAF and Rehook it up do I gotta restart the computer or no?
Old May 10, 2005 | 07:08 PM
bardabe's Avatar
Bad Speller
yes unplug your battery for a couple hours or over night. u need to pretty much reset it. I also removed My MAF when I wrecked my Z WELCOME TO THE CLUB!
Old May 10, 2005 | 07:54 PM
z32gizzle's Avatar
awsome bro thanks for the quick reply. *Grins as he removes the battery clamps*
Old May 10, 2005 | 08:21 PM
91zxtt's Avatar
Bardabe, what are you talking about? Why would he need to reset the ecu on this? He hasn't changed anything.
Is the MAF connected or not? If it's not, then plug it in. The car won't run right without it. If it is connected and you're having problems, then check the ecu for any fault codes. How hard were you hit? The MAF is a very sensitive piece of equipment. It could've been damaged of you got hit hard enough in the front. It's a strectch, but possible.
Old May 10, 2005 | 08:28 PM
ZXDude90's Avatar
Aqua Teen Hunger Force Fan
I busted one of the screens on mine today Anyway I can just get the screen replaced?
Old May 10, 2005 | 08:39 PM
z32gizzle's Avatar
it was a front right hit just basically my right fender and front right of body Heres a pic of it
Denver93TT's Avatar
As long as you keep a good filter on it and are careful when they are changed then don't worry about it.
Old May 10, 2005 | 09:31 PM
bardabe's Avatar
Bad Speller
well I went under the car and Busted the screen. It dosent matter if U have a screen or not If U ask me atleast. does it matter if U have a screen or not?
Old May 11, 2005 | 11:47 AM
b300z's Avatar
caught the z fever
no screen allows more air to come in, but it also allows more debris to come in. it can also confuse the MAF because of the greater volume of air coming in, making the car run richer
Old May 11, 2005 | 02:34 PM
z32gizzle's Avatar
K well the whole MAF replug and uncap battery didnt work now it wont even start...It will kick over but then it just quickly dies...any ideas?
Old May 11, 2005 | 04:36 PM
b300z's Avatar
caught the z fever
did you clean the connection?
uhhh do you have gas?...j/k
does it sound like all 6 cylinders are firing?
Old May 11, 2005 | 06:47 PM
z32gizzle's Avatar
lol there was like some gunk on the connections...cleaned it and its all good now! Thanks for the input guys
Old May 15, 2005 | 05:10 PM
91zxtt's Avatar
No screen on the MAF does allow more air in. Dirt shouldn't be a problem since it sits behind the air filter. Some peopler have removed them in their cars and believe there is a noticeable difference; however some have removed them and had it cause problems. Apparently the air that travels through the MAF without a screen tends to be more turbulent; which can confuse the MAF.
Just an FYI
NISMO LMR
Jul 28, 2004 10:57 AM
