My 92 Twin Turbo ... The Story So Far
Old Feb 24, 2010 | 11:38 AM
tomtastic's Avatar
Ok, so I've had it for about four days now, long enough to know what stuff it needs save for some of the mechanical things which I'll be checking when the weather is warmer.
Paint is descent, couple of hail-sized dings in hood but everywhere else is free of blemishes.
Missing items: defroster button cover (have ordered), clock (have ordered), hatch cover, t-top shades and bags, the black trim on back that says nissan and twin turbo (want to get this one soon!).
Replaced a headlamp relay and got the vanity lights working, can't find the hood light or the hatch light, not sure if it has them or where they're located. All other lights are functional.
Hood has some gap issues, which causes the alarm light to flash. Need to get that fixed. It closes fine but there's some give in the latch as you can still press it down some more until it hits the secondary lock. If it can be adjusted so it was tight without any give it should close the gap and fix the alarm problem. Might be why the fuse was missing for the theft system.
The hood window washer jets are broke underneath, not sure where to get those, parts store said go to Nissan.
Hatch release lever doesn't open hatch, there's a faint click but I don't hear any motor running. Is it a motor or just a cable release? Opens fine with key. It also needs shocks, it fell on my head once, ouch! It's heavy.
Radio doesn't work, but it's stock so no big loss there, trying to decide which cable is the antenna for when I add a new head unit. Thought it might be the double prong cable. Not sure. Checked with meter for power and remote power and they're working not sure about ground, need to look some more.
The major problem with it right now is the steering wheel is off center by about 90 degrees. Not sure why or what would cause it. It doesn't pull left or right when driving. I'll probably take it in since it has airbag. Don't want to mess that up.
Has original exhaust I believe, the big cans angled upward and out. There's a leak where they connect to the pipes. I'll get some new gaskets for them and get them sealed up. I'll probably switch out for some cat backs eventually. But it actually doesn't sound too bad as is.
Well, that's about it for problems at least until I check the ecu and some other things. It's got an airbag light on and the hicas light came on when I was driving it home but it hasn't come on since. Maybe the ecu diagnostic will tell me more. Hopefully just a sensor out on those two.
I put a clean piece of cardboard under the front end the first night and there were a couple of drips on passenger side toward front and then nothing for next 24 - 48 hours later and then the last two days it hasn't leaked.
Going to change oil when it's warmer and clean out the cooling system. Has synthetic in it now so I'll probably stick with it.
Just had a timing belt replaced and water pump. Not sure about plugs. Injectors look pretty old, not sure if they need replaced unless it's recommended.
Ecu looks like it's been upgraded to a JWT, probably the 370/fed from what I'm learning. Has a single intake and probably the stock injectors by the looks of them.
It's an auto, but no car's perfect, but I'm too old to be shifting like a kid anymore. But the auto's pretty nice, has a nice overdrive in it. And it's nice to be at a light and just punch and go.
Car runs smooth, seems like it has a lot of power, maybe more than stock. From what I read the JWT adds about 60 Hp.
Future plans: Not going for a 1000 HP Track Car. Probably somewhere around 400 would be fine with me. I'll probably just replace the exhaust and some minor engine parts. Plan on keeping stock turbos, might replace injectors but will keep them stock size since already have ecu upgraded for stock injectors.
But it's not bad now, needs a few things and some repairs and should be good to go. Maybe I can get some pics up when it's nice outside, it needs a good washing and the interior cleaned. Interior's good on it. Only one half-dollar-sized hole in the driver's seat on side. Other than that it's pretty good.
All in all, not bad for 18 years old.
Old Feb 24, 2010 | 11:47 AM
KasbeKZ's Avatar
Pr0n Addict
Adjust the hatch latch. Fairly easy. Stock exhaust is quad. Sounds like you might have hks catback.
Old Feb 24, 2010 | 03:44 PM
tomtastic's Avatar
Oh, ok, haven't seen a lot of pics of stock 300s' exhaust. Not sure what the mufflers are, looks stock from pipes on up to motor. I'll get some pics on here in a couple days.
Old Feb 24, 2010 | 04:31 PM
KasbeKZ's Avatar
Pr0n Addict
basic stage chart. shows you where to start with your upgrades. post pics of your exhaust. it could be a decent system like hks and already be upgrading you, or it could just be pep boys mufflers half-assed welded on there. like the P.O. of my car has done...
SGP Racing's Chart for TT
90-96 Nissan 300zx-TT
Staged Upgrades
STAGE 0
Stock 280-300HP
SGP STAGE I
JWT POP Charger/Underdrive Pulley
305-325HP@10PSI
Improved Low End Response
SGP STAGE II
JWT ECU Upgrade
365-380HP@12-14PSI
Removes Limiters/Expands Fuel, Timing,
and Boost Maps/Increases Boost
SGP STAGE III
SGP Test Pipes/Gut Pre-Cats
385-400HP@12-14PSI
This Upgrade Will Shock You!
SGP STAGE IV
Cat Back Exhaust
400-415HP@12-14PSI
No Exhaust Restriction/Great Boost Response-Car Pulls Hard
SGP STAGE V
Boost Controller
420-435HP@15PSI
Steady Boost Response;Control/Solid 15PSI Of Boost
SGP STAGE VI
JWT NOS System
490-505HP@15PSI
Car Shoots Out Of The Hole/System Engaged Until 10PSI
SGP STAGE VII
Intercoolers / Radiator Upgrade
495-510HP@15PSI
A Must Have For Future Upgrades/Increased Cooling Efficiency
SGP STAGE VIII
JWT Twin POP
510-525HP@15PSI
No Intake Resrtiction/Turbos Will Sing
SGP STAGE IX
Ported Trottle Bodies/Matched Intake
515-530HP@15PSI
Car Now Ready For Injector/Turbo Upgrade
SGP STAGE X
555 / 740 / 850cc Injector Upgrade
530-545HP@17PSI
Now Able To Increase Boost/Upgrade Turbos
SGP STAGE XI
Sport 500 Turbos
555-575HP@17-21PSI
If you plan to go above this stage, engine upgrading is suggested for durability reasons. The next stages will take you above 500RWHP! If you plan to take your Z over the 650RWHP mark, you will need a higher capacity Fuel Delivery system. please check the Fuel system section for more info on how SGP can help.
Greddy TD05-16G Kit
560-605HP@17-21PSI
SGP Racing TD05-18G Upgrade for the Greddy Kit
(Cam Upgrade Required)
620-675HP@17-25PSI
SGP Racing TD06-20G Upgrade for the Greddy Kit
This kit has 650-750 RWHP Capability +
SGP STAGE XII
Cam Upgrade/SGP Head Package
Package Includes Three Angle Valve Job, Port & Polish
Race Package Includes Five Angle Valve Job, Port & Polish, New Valve Seats for the SST or Alloy Oversize Valves,& Bronze Valve Guides.
Valve Springs, Cams, and Retainers are required for this level, and are not inluded in Race Package.
mawillis30
FS: 300ZX (90-96)
May 23, 2015 06:25 PM
rcljrmann
Jun 13, 2011 05:01 PM
johnsonsz31tt
May 7, 2008 07:27 PM
teamadidas
Jun 2, 2005 04:41 PM
presto
Jan 31, 2004 03:26 PM
