More shit.
More Problems.
So i get the car started and running good with the new plugs. And now i get this gas smell after driving for like a half hour. Could it just be from like three weeks of over-flooding. Check Engine light doesnt come on, so i dont know.
Hmmm, not likely. Sounds like you have a fuel leak elsewhere. Take the plenum cover off. It'll give you a better look at some of the fuel lines. Look around the base of your injectors. If you see anything wet, then that's likely where you're fuel leak is. Hopefully it's just a fuel line that needs to have a clamp tightened, but with the other problems you've had, I'm suspecting you have a problem, or several problems with one, if not several injectors. So, like you said, more ****.
Well. It went away. Las night i had to follow my friend to drop his car off, the drive was a solid hour and half, the bas smell never occured, and when I got home it wasnt there either. I dont know. Im off today so I think ill spend a while checking it out. Ill keep all posted.
Originally Posted by rizzspeed
Don't wanna sound like a jerk but watch the language a bit guys, especially in thread titles.
Thanks.
Thanks.
Injectors are dry, I checked them out this moring. I ran the car, and the lines, and they were all dry. The smell is still not there, im gonna check out some other things thou, damper, regulator, stuff like that.
