intake sensor mod on ebay
Old Oct 22, 2002 | 11:30 AM
Re: intake sensor mod on ebay
It has something to do with either modifying the signal of the air temperature or head temp sensor. They are usually a "volume" control that regulates olhms passing through a wire. The "volume" **** is the adjuster. It will richen or lean your fuel mixture. Possibly adding 5-10 horsepower to a well modified n/a engine. No way could it add 20hp unless you are running a turbo charged engine and your computer is not working right to give you the proper fuel mixture. Its a 2-dollar Radio Shack item, and basically a scam. You can make one yourself if you are curious.
I heard of someone doing that to the head temp sensor on an n/a 280zx, and it sorta worked. Maybe added a couple pounds of torque. Just barely enough to notice. It also decreases your milage when activated.
DocBombay
Nov 28, 2006 08:09 PM
stinky
FS: 300ZX (84-89)
Nov 15, 2005 12:59 PM
KTM200-280zxt
May 25, 2005 05:28 PM
carloz
FS: 300ZX (90-96)
Jan 31, 2005 12:38 AM
lightspeed
Oct 21, 2004 12:57 PM
