Idle
Old Jan 11, 2005 | 07:49 AM
Lucky91647's Avatar
From: Currently: San Diego, CA; Originally: Redding, CA
Idle
Ok stupid question. Where is the Idle adjust? I was thinking on the throttle control rod (my terminology), on the right side. Am I close?
Old Jan 11, 2005 | 10:25 AM
b300z's Avatar
caught the z fever
its on the iacv in the back corner of drivers side...sorry not too descriptive at the moment
Old Jan 11, 2005 | 07:55 PM
91zxtt's Avatar
It sits on the back of the plenum, on the driver's side. The adjustment screw points towards the brake master cylinder.
Are you having a problem with a high idle?
Old Jan 11, 2005 | 08:09 PM
b300z's Avatar
caught the z fever
if you are here are a few links that might help
http://home.swipnet.se/e-solutions/IdleTech.html
http://home.swipnet.se/e-solutions/IdleTech2.html
https://www.zdriver.com/forum/archive/index.php/t-10057
https://www.zdriver.com/forum/archive/index.php/t-9914
Old Jan 12, 2005 | 12:55 PM
Lucky91647's Avatar
More of a low idle. When the car's warmed up and just sitting, the rpms are below 1000, which is lower than a friend's with a 91TT and every once in a while it'll dip lower and the car almost dies.
Old Jan 12, 2005 | 06:21 PM
CanyonCarver's Avatar
Jack Of All Trades
fsm says:
manual trans n/a & tt 700 +/-50 rpm
auto trans in neutral n/a 770 +/-50 rpm TT 750 +/-50 rpm
if it wants to die at idle, check for vaccum leaks, bad electrical connections, and then there's the cleaning of the t/b's and the iacv, just to start.......... :cheers:
Old Jan 13, 2005 | 06:41 PM
Lucky91647's Avatar
Funny thing is it's not an all the time thing.
Old Jan 13, 2005 | 07:46 PM
91zxtt's Avatar
Sounds electrical....fun stuff. Does it want to do it more when it's hot or cold? Does it want to do it when you turn on any accessories (AC, fan, lights, stereo, etc.)? If so, then it could be one of the components to the IACV that has a bad connection. I wouldn't mess with the idle screw since it's intermitent.
Old Jan 18, 2005 | 06:08 AM
Lucky91647's Avatar
It's only when its warm. I haven't really tested electrical components. My stereo's always on but it's a cheapy little thing I doubt it's that much of a draw. I'm sure the install is totally screwed though. How would an electrical component cause the engine to die unless my alternator wasn't working?
Old Jan 18, 2005 | 01:02 PM
My Fairlady Z's Avatar
Ruined By Spudz
Is it normal that whenit's cold out my car runs at about 900-1100 idle but in normal temperatures it runs at a normal 700..
Old Jan 18, 2005 | 01:39 PM
b300z's Avatar
caught the z fever
it is if the idle goes down after the car has warmed up for a while
unlike my last car that went up to 2k when it was running...wow i have a lot of stories about that car
Old Jan 18, 2005 | 03:43 PM
Ruined By Spudz
Care to share some? Start a thread in Off-Topic and enlighten us.
Old Jan 18, 2005 | 04:51 PM
b300z's Avatar
caught the z fever
:chug: :blah: :blah: ill give it my best shot
Old Jan 19, 2005 | 07:56 PM
91zxtt's Avatar
Everything on these cars is controlled electronically. Could be a bad connection, or a bad sensor. Try cleaning the throttle bodies, like CC mentioned. That's an easy place to start. If that doesn't work, then I'd focus on the IACV. In my mind I use the following equation.... intermittent problem = electrical problem. You may want to look into a grounding net also. That could help.
Old Jan 19, 2005 | 08:15 PM
Jack Of All Trades
Everything on these cars is controlled electronically...........
Except for that nut holding the steering wheel in mine........ ha ha .....lol........ j/k....... ohhh.......... sorry .......
t:
Old Jan 19, 2005 | 09:12 PM
91zxtt's Avatar
You just crack yourself up, don't you?
madkiwi
Jun 6, 2015 07:40 AM
originalzboy
Feb 8, 2014 09:46 AM
kiboy6
Dec 13, 2008 01:53 AM
cartune77
Jan 28, 2005 11:21 AM
CL1
Aug 25, 2002 02:39 PM
