grinding tranny noise please help
Old Mar 17, 2003 | 08:13 PM
silvrhand's Avatar
Snazzy Title
Ouch,
How many miles are on it, more than likely it's the synchro's or could be a really bad throwout bearing..
You are going to have to take it apart to know for sure, and that does sound like the uv joints, you are just going to have to get it up on a rack and take it down.
Beware, the tranny is a pain to get down, you have to pull the exhaust, all the way up the the downpipes..
Old Mar 18, 2003 | 09:07 AM
drag_300japan's Avatar
Well You wont really know whats untill you take it apart. One thing that you can do if you have a lift that you can use is to flush the trany out. When you drain the the fluid put some cheese cloth over the pan to catch the metal so you can see what color the flakes are. this will give you a better idea as to what parts are bad. the syncros should be made out of a yellowish brass color. The gears are silver in color.
Projerkit
Jan 30, 2013 07:55 PM
vuez32
Nov 11, 2011 10:15 AM
Piascyk
Nov 16, 2007 10:03 AM
NateB
Oct 12, 2005 12:04 PM
kansaskeith
Dec 7, 2003 10:19 PM
