Grinding Noise
Old Sep 21, 2005 | 06:13 PM
NateB's Avatar
Grinding Noise
I've got a '90 n/a and about once in every 10 times i go to start the car it makes a grinding noise (like the noise a car makes when u start it when its already on) and doesnt start up, then i will turn the key again and it starts right up. Now im pretty sure this is a common problem for the Z32s because the one i had before this one did the same thing, but i sold it before i got it checked out, and my roomates did it also, but he donated it before getting it checked out. and now this one started doing it @ 145000 mi. Im pretty sure its either the ring gear or the flywheel, but i hope its not the flywheel that i have to get replaced. if anybody has experienced this problem or knows about it and what it takes to fix it, please let me know, it would be greatly apreciated.
Old Sep 21, 2005 | 06:33 PM
emo236's Avatar
confuzed member
Yea, mine does the same thing. It's not something to really worry about fixing for me. It's very seldom and it always starts after that without any issues.
Old Sep 21, 2005 | 07:58 PM
91zxtt's Avatar
It's your starter. It could be that the bendix is not lubricated well enough and is sticking. You could remove the starter and clean and lubricate the bendix. Mine used to do it. Moreso when it was cold.
Old Sep 22, 2005 | 04:12 AM
CanyonCarver's Avatar
Jack Of All Trades
Correct. Moisture tends to get inside over time causing it to stick. For other vehicles, I have bought and replaced just the bendix (solenoid). It's not exactly good on the flywheel to have this happen.
I have also fixed this problem by cleaning the battery and starter wire connections.
Old Sep 23, 2005 | 01:15 PM
KevinH's Avatar
Same with my '93 NA
I experience the same thing with my '93 Z32! My girlfriend drives this one predominately (I drive the '90 2+2 . Anyways, we've noticed that if you put the car in nuetral (manual drive) before you try and start it, it doesn't happen. I do not have an explaination for this, only know that it is the case from experimentation.
I remove the starter, if I can find time that we are both off at the same time, and lubricate the starter as mentioned above.
Thanks!
Old Oct 12, 2005 | 12:04 PM
kevtt's Avatar
is this something you find at your local autozone?
Projerkit
Jan 30, 2013 07:55 PM
vuez32
Nov 11, 2011 10:15 AM
Piascyk
Nov 16, 2007 10:03 AM
kansaskeith
Dec 7, 2003 10:19 PM
Mioduz
Mar 18, 2003 09:07 AM
