Gas smell in car and loss of power
Old Dec 18, 2010 | 01:40 PM
andrew404's Avatar
I have a 1990 300zx NA and after I start and drive it for a few minutes a strong gas smell comes into the car. What could be causing this? I've also noticed that the acceleration has bogged down a lot.
Old Dec 18, 2010 | 06:08 PM
If you are smelling gas and it feels like the car is losing power and you are getting crappy gas mileage, chances are you have a fuel leak.
Old Dec 18, 2010 | 08:41 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Yeah... and it doesn't take a mensa member (much less a regular human being) to figure out that gas smell + loss of power = fuel leak.
Old Dec 19, 2010 | 08:44 AM
andrew404's Avatar
Ok... Is there an easy way to find out where the leak is? I haven't seen any gas that leaked underneath the car.
Old Dec 19, 2010 | 09:33 AM
It wont usually be that easy. You probably have a fuel line or maybe an injector o-ring leaking, or bad. etc...You just have to pinpoint, where the smell is coming from. Then look around that general area. Good luck.
Old Dec 19, 2010 | 09:47 PM
You haven't seen any gas under the car because it's evaporating before it gets there.
Tighten all the fuel hose clamps - loosening over time is the #1 cause of fuel leaks. If that doesn't remedy the issue... http://twinturbo.net/ttnettech/fuelleaks/fuelleaks.html
Old Dec 20, 2010 | 10:46 AM
domsgarage's Avatar
Tough Guy
gas evaporates, my dude.
domsgarage's Avatar
Tough Guy
beat me to it.
Old Dec 29, 2010 | 08:00 AM
andrew404's Avatar
turns out i need new fuel injectors. anybody have any recommendations of good aftermarket brands, and are refurbished ones okay or should i stay away from them?
Old Dec 29, 2010 | 03:43 PM
I have a set of good set of old style N/A injectors I'm selling. $105 shipped in the US. (they ohm between 12-12.2)
Old Dec 29, 2010 | 05:47 PM
Stick with OEM. Go used if you need to save money, but just know that you're going to continue having injector failure until you retrofit to the newer style injectors. Thank our government for the ethanol fuel blend that's causing your injectors to die. (And please don't ask about the details - there are posts on here and twinturbo.net detailing everything you would ever need to know about the retrofit.)
But I also don't think bad injectors are the cause of your fuel smell.
Old Dec 29, 2010 | 06:33 PM
bnhunt's Avatar
For what its worth, i've found cold starts are the best time to locate leaks. I'm guessing the pressure is higher while the car is cold and also the engine isn't hot yet so the fuel won't evaporate so quickly.
Old Dec 30, 2010 | 06:39 AM
ttxz003's Avatar
I agree, but if your going to go through the trouble to replace one injector, check your budget and change or upgrade them all.
Old Dec 30, 2010 | 10:38 AM
Actually, it's because the rubber hoses expand when they're warm, thus sealing the leaks. As per my earlier link: "Fuel smells will usually start during colder weather, since the parts contract even more in the cold air during a thermal cycle."
Fozy
Mar 28, 2011 07:42 PM
mikesz
May 29, 2008 11:06 AM
Cw2435
350Z Performance / Technical
14
Feb 22, 2004 10:33 PM
Cw2435
Jan 18, 2004 05:29 AM
280zdriver_16
Jan 9, 2004 10:39 AM
