Gas smell
Ok, I have a problem and I think it should be fixed right away, lately I have been smelling fuel around my car and inside when the defrost is running... what are the first things I should check? the fuel lines? I know I need to fix this right away but not sure where to start (Im a noob)...
I just had this problem fuel lines, fuel pressure regulator, fuel damper, fuel filter. I was running really rich, it was the coolant temperature sensor, a fuel line, and pressure regulator.
this might help https://www.zdriver.com/forum/showth...ighlight=smell |
ah... any suggestions on where in San Diego I could take my car to have it looked at? I dont feel comfortable enough under the hood to be messing with my fuel system.
This job isn't as hard as you'd think, follow the write up and you'll do fine. This is one of the first things I ever did on my old TT since it had the fuel smell when I bouhgt it. It was a good job to get to know the car a little more. Just remember to depressurize the system. I'm also in SD and would be willing to help out if I had time. Gimme a PM if you think you need a hand. I do encourage you to do this one yourself, it'll be a great learning expereince and save you tons of dough.
Also, please try to search before posting a new topic. This topic was just discussed as you saw in the link. thanks!
Yeah I am no mechanic and havent had much experience on foreign cars until now, and I didn't have a hard time fixing my leaks. Im positive that if I can do it, you can too.
Yea, if you know which line is the fuel line, then you can likely fix it. Just follow the fuel line from the filter to the return and tighten all the clamps along the way.
Tis the season for fuel leaks.
