F*cking Headers.
Old Feb 6, 2004 | 11:00 PM
NISMO LMR's Avatar
F*cking Headers.
Any ideas on how to remove the exhaust manifolds bolted onto the heads. It is vurtually impossible to remove the heads without doing this. And Im stumpted... I cant reach the bolts. Peace foo's
Old Feb 7, 2004 | 12:41 PM
Riz Z Speed's Avatar
Administrative Brown Guy
http://www.300zx.co.uk/cgi-bin/manua...fault&total=70
Well, according to the online manual, you should remove the cylinder head and the exhaust together as one piece then disassemble once it's all out.
Old Feb 7, 2004 | 12:48 PM
NISMO LMR's Avatar
Yea I just say that on page EM-28. But how do I get to the main pipe then? Peace foo's
Old Feb 8, 2004 | 12:24 AM
Disconnect the header from the exhaust from underneath. It should be easier to reach the end of the header than the beginning of it from underneath the car.
Old Feb 8, 2004 | 08:11 AM
NISMO LMR's Avatar
Yea im working on it today. It should be somewhat fun, kinda sorta, not really. haha Peace foo's
Old Feb 8, 2004 | 04:17 PM
NISMO LMR's Avatar
I cant get to them... I cant get the car up, I cant get it from the engine bay, my arms are too big to squeeze in there... Any ideas? Peace foo's
Old Feb 8, 2004 | 04:23 PM
Z_WRECKER's Avatar
get someone with skinnier arms
Old Feb 8, 2004 | 04:35 PM
NISMO LMR's Avatar
Haha, have you messed with them at all? I have no clue how to go about it. Peace foo's
Old Feb 8, 2004 | 04:36 PM
Z_WRECKER's Avatar
no i haven't luckily they were on the car when i got them
Old Feb 8, 2004 | 04:38 PM
Z_WRECKER's Avatar
well that previous post didn't make sense... i haven't messed with them
Old Feb 8, 2004 | 05:06 PM
91zxtt's Avatar
Um, I know this is going to come out wrong, but why can't you get it up?
Old Feb 8, 2004 | 05:48 PM
Z_WRECKER's Avatar
i am sure 91zxtt meant to say car.... why can't you get the car up just trying to keep it G rated
Old Feb 8, 2004 | 07:13 PM
NISMO LMR's Avatar
BBWWAAHAHAHAHAHAHAHHAHAHHAHHAHAHHAHAHAHA DUUUUUDE thats a good one. Because I dont have a garage jack... Any ideas? Peace foo's
Old Feb 8, 2004 | 07:20 PM
Z_WRECKER's Avatar
you need to get on man...it's a must
91zxtt's Avatar
Use your jack that came with car. It'll take some time, but at least it'll give you access from underneath. Get the car up in the air high enough to put 2 X 6 blocks of wood. 2 X 4 are too skinny and the factory jack is obviously not sturdy enough to trust with your life. Four 2x6's should work well on each side. Also, by doing this you can take the belly pan off and grab all the parts and tools you've dropped over the past couple of months.
Old Feb 8, 2004 | 07:23 PM
you mean jack for the car, not the garage. Unless you're wanting to jack up the garage.
The car should have a jack. Don't have any jack stands?
Old Feb 8, 2004 | 07:35 PM
Z_WRECKER's Avatar
hhaha knowing him that wouldn't suprise me
Old Feb 8, 2004 | 07:37 PM
NISMO LMR's Avatar
Haha, you get my drift man. I think I could probably get it up, but its scary getting under a car that rides less than 5 inches from the ground, and my chest being about 12 inches. I cant imagine that would feel good. I've had some bad experiences with cars falling around me... Riz knows, 1969 Chevelle? Never take an engine out while its on the lift... "ooops... That can be welded back on right?" Haha. Peace foo's
Old Feb 8, 2004 | 09:06 PM
91zxtt's Avatar
Aw, come on. These cars only weigh about 3300 lbs. You can handle it.
Old Feb 9, 2004 | 03:39 AM
Z_WRECKER's Avatar
just put some elbow grease on it
Old Feb 9, 2004 | 01:40 PM
NISMO LMR's Avatar
Yea 'cause tall know im chuck diesel, I aint afreaded of no 3300 lb car. Haha. RIIIIIGHT. Peace foo's
Old Feb 9, 2004 | 06:29 PM
91zxtt's Avatar
My guess is that if it did fall it would only hurt for a second, maybe two. J/K If you place the jacks in the proper places, then you'll be fine. Just make sure the e-brake is set and block the tires. Place blocks of wood under the front tireas as well, if you're really paranoid.
Old Feb 9, 2004 | 08:20 PM
NISMO LMR's Avatar
Im going to put 4 cynder blocks, two on each side of the car, on the proper lift positions. To support the car, and blocks underneither each wheel. And I dont even think it would hurt for a second, I think I would end up just passing out before it happened, haha. Peace foo's
Old Feb 9, 2004 | 11:43 PM
91zxtt's Avatar
Make sure you use some duct tape in there also. Just to be safe.
Old Feb 10, 2004 | 02:10 PM
Z_WRECKER's Avatar
and ribbots ( haha) i mean rivets
