engine rough when warm
Old May 11, 2004 | 09:29 PM
OrangeZ32's Avatar
Well you've come to the right forum, Its a very difficult problem. When you ran the ECU Diagonostic did it come up with anything else cause the ECU should sense that. It does sound like a fuel problem, cause something is not flowing smoothly from you fuel cause your hesitation definatly sounds like fuel related. Check your fuel lines, filter, everything, etc. Whatever it is I can garantee it's not gonna be a fun job. I've never run into any problems like this but the 90-91's have various small little problems i would recommend checking out Rizz's signature and going to the nissan online service manual. But run an ECU check again and see what readings you get an go from there.
Old May 13, 2004 | 11:17 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Dumb question, but I gotta ask.........
You are using 93 octane premium fuel right???
Sorry, I had to ask.
Assuming that's ok. I'd double check the connections to the Coil Packs. Measure them with a multimeter, they should all read about the same resistance. Same with the injectors. Check the online service manual for what values that you should be getting.
Another question for you.....What spark plugs did you use? I hope they're the factory equivalent NGK's.
uranus
Jun 23, 2024 07:07 PM
jjk_52
Mar 29, 2014 07:48 AM
mrdark
Oct 26, 2012 04:31 PM
88300zx
Apr 27, 2012 01:58 AM
mrprofile
May 17, 2011 04:48 PM
