Egr
Old Jan 3, 2011 | 04:24 PM
hardenstine's Avatar
Egr
so im going to delete the EGR but the kit I got did not come with the bolt that goes in the exhaust manifold does anybody know what size I need?
Old Jan 3, 2011 | 08:01 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
They actually sell the same plug at AutoZone. Go into the aisle that has all the hot rod and engine dress up stuff. As for the size, just go to Home Depot with the tube and match it to their thread pitch thing.
Old Jan 7, 2011 | 03:44 PM
ok so let’s say i did this i sandwich the plates in between the EGR tubes and the plenum and disconnect the the vacuum line. If the vacuum line is not on it won’t open right? So why should I have to take the line off the exhaust?
Old Jan 7, 2011 | 05:10 PM
Mrmoose's Avatar
that will work, its just better to remove the lines because there is a lot of pressure in turbocharged cars exhaust system... clamp the lines in a few spots to make sure its tight.
Old Jan 7, 2011 | 05:25 PM
its a N/A
Old Jan 7, 2011 | 05:29 PM
plus i like to keep on just in case i move to a state that test
