diff replacement
Old Mar 4, 2007 | 12:36 PM
entropy31's Avatar
The Cake Is A Lie!
diff replacement
ok, so the whine from my diff is becoming unbearable. time to replace that sucker as soon as i find a replacement for a decent price. i have the FSM, and it looks to be a no brainer, but is there anything i should know about that isnt covered in there. i dont want surprises. and anything else i shoud do while i am down there?? depending on funds, i was thinking of replacing the diff bushings with ES bushings, and possibly the driveshaft with a one piece.
Old Mar 4, 2007 | 02:46 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
If you don't have subframe spacers, you might as well get them and do them when you're putting everything back together. Similarly, if your subframe bushings are original (or haven't been replaced in a long time), I'd recommend getting the Energy Suspension repalcements. I have to replace mine once weather gets nicer - when they go bad, the subframe starts wobbling and making a lot of noise.
As a general rule of thumb, if you're going to have suspension parts removed, bushings are always a good thing to replace (unless they're new).
Old Mar 4, 2007 | 07:05 PM
send it to ron's rear ends down here in cali, he's about the best rear end guy in the US.
Old Mar 4, 2007 | 10:01 PM
bardabe's Avatar
Bad Speller
VLSD's can;t be rebuilt, he only has 2 options
A) cheap replacement
B) Upgrade
Just go with B and get a Nismo, Kaaz, or TOmei 2 way. diferential.
Old Mar 4, 2007 | 10:15 PM
entropy31's Avatar
The Cake Is A Lie!
send me the money for it and i'll do it .
Old Mar 5, 2007 | 05:32 AM
CanyonCarver's Avatar
Jack Of All Trades
VLSD's can;t be rebuilt, .
And where might this information come from? Of all of these differentials that exist on this planet, I find that very hard to believe.
Old Mar 5, 2007 | 09:18 AM
bardabe's Avatar
Bad Speller
right now im banned form the forum that I got this info from (i got in an argument with a mod, I won, he got mad and abnned me for a month how mature) pretty much is on how Viscus Diferentials are made. its not the same as a clutch type diferential. but ehhh no time to really erxplain now I'll get you full details later
Old Mar 5, 2007 | 11:03 AM
Jack Of All Trades
I'm pretty sure the guys that are installing the new Leader Gears and all, are doing a freshening on the diff. I highly doubt they're putting new gears in with old bearings, shims & seals.
The whine is generally a bearing going bad, or something changed to where the gear teeth aren't engaging at correct pitch line anymore. The vlsd part of the diff may not be rebuildable, but the most common failures are bearings and grears ..... ring & pinion that is.
Old Mar 5, 2007 | 11:40 AM
yeah, this might not be doable for you if your not up for shipping but here
http://www.zcar.com/classifieds/inde...fromfromid=34&
Old Mar 7, 2007 | 04:17 PM
Boosted Z's Avatar
Banned
for 1150 you can have a brand new carbonetics carbon lsd 1 way,1.5 way, 2 way. It comes with all new inner and outer races and new oil seals and stuff to refresh you beat up diff. also Z1 sells good used diffs low miles for 350 I think I bought one and i still have it its in good shape and works great!
Old Mar 7, 2007 | 05:39 PM
hell, he could buy a better used diff off ebay for less then $200
Old Mar 7, 2007 | 07:38 PM
MikeZ's Avatar
I have a whine as well coming from the rear of my 95' Z. I've heard it for the last 15,000 or so. Is this the same thing? It's not really loud, but it is definetly audible.
Old Mar 7, 2007 | 09:10 PM
entropy31's Avatar
The Cake Is A Lie!
carbon lsd??? no thanks. why would i blow $1150 on crap i dont need?? my car is a rice free zone. a used stock one in decent shape will suit me and my wallet just fine.
Old Mar 7, 2007 | 10:00 PM
wreckedj30's Avatar
No Club Love
my friend down here has a 300zx in the yard, that a guy was suppose to be working on his camero...long story short its his, and he'll be stripping it soon....i'll ask for the price!
Old Mar 8, 2007 | 06:30 AM
Boosted Z's Avatar
Banned
rice free zone? hahaha thats funny how is having a high end diff ricey? its not crap actualy it makes teh care handle a hell of alot better but i guess you never know will you
Old Mar 8, 2007 | 08:58 AM
My friend in Yelm might still have a turbo diff if you're desparate. I know its geared taller but... its out of a low mile Twin Turbo, RHD!
Old Mar 8, 2007 | 12:44 PM
Boosted Z's Avatar
Banned
To put turbo diff in a N/A Z is lot of cuting and welding to make the place where the old bolts used to go to new spots for the bushings and bolts. also you would need to change out the axles for turbo axles because there 6 bolt, and also a new driveshaft because of the cv joint,(n/a is 4 bolt)
Old Mar 8, 2007 | 03:21 PM
oh, I did not know that. I had heard of people putting the 4.0 geared NA diffs into the TT all the time. I didnt know they had to change stuff.
Aren't they both R230 units?
Old Mar 8, 2007 | 05:58 PM
entropy31's Avatar
The Cake Is A Lie!
i'll put the carbon lsd in right after i finish with my hydro power install .
Old Mar 8, 2007 | 06:26 PM
RodMoyes's Avatar
Doesn't post much...
Oh Snap!
Rod.
Old Mar 8, 2007 | 06:28 PM
Jack Of All Trades
Wrong...... it's a straight across swap. The tt and n/a sub-frames are interchangeable.
Old Mar 8, 2007 | 06:44 PM
bardabe's Avatar
Bad Speller
I will enlighten your responce
basically when people put the N?A rear end on their TT's they literally mean the rear end. they swap, Subframes, diffs, axles, and most of the suspension. (still can;t name all the suspension components exactly) they also do this to help the HICAS elimination cimpletly.
Old Mar 9, 2007 | 09:05 AM
Jack Of All Trades
listen the subrames are the same yes u can swap the SUBFRAME.
but to swap a diff on a N/A to TT you have to cut and weld maybe some one should carify what there talking about b4 they open there mouths up its a f***ing kiddy game on this site. im right. i wasnt talking about a sibframe swap i was talking differntials only. the reason being is because bleach said his buddy has a tt diff so i said what was needed to be done to put a tt diff in a N/A subframe!!!
o.k. ...... don't get so defensive.
Old Mar 9, 2007 | 09:56 AM
Boosted Z's Avatar
Banned
my bad but every one needs to clairifly what they say for now on. because every one turns stuff around and makes every body sound wrong yes if I said i couldnt swap a tt SUBFRAME in to the N/a you would be 100% right your right but bleach was only talking about the differntial so every body comes on an starts thinknig we are talking about the hole subframe and not ask " hey are you guys talkin about just swaping the diff or the hole subframe?" no 1 asked. but heres a good question for yah. ok can you swap a tt subframe in a N/a 2+2? i will have to say no on that one. so techicaly speaking if u said n/a and didnt say how many seats you could have bin wrong to. but in the same sence right beucase no one clarified that.
Old Mar 10, 2007 | 07:44 AM
b300z's Avatar
caught the z fever
i dont think the subframe is any bigger in the 2+2
