custom or labree?
Old Jul 30, 2006 | 10:35 PM
hydro341's Avatar
custom or labree?
hey guys i have a 93 n/a 2+2 and i want to get some kind of an exhaust system. ive looked at the labree exhaust and also have the idea of getting a custom exhaust. im leaning more toward the custom exhaust, getting the labree mufflers and going to a muffler place. if i go the custom way what am i suppose to tell the guys at the shop on what to do? will i have to get resonators and catbacks or whatever and use 2.5" piping, and when they do the piping what will they replace? any feedback would be appreciated thanks guys.
Old Jul 30, 2006 | 10:44 PM
tell them that you want a 2.5" mandrel bent exhaust, then add what ever cat you want.
Old Jul 30, 2006 | 10:48 PM
why would you add a cat if its a cat back section? resonators mabye.....but not neccessary, i would get them though just cuase the noise supression makes a more pleasing note...otherwise it is raspy.
Old Jul 31, 2006 | 08:26 PM
b300z's Avatar
caught the z fever
he never said anything about adding cats...catbacks yes, which didnt make complete sense either, but....
im not sure what exhaust shops has as far as x-pipes or H-pipes go, so if you went with an exhaust shop setup with labree mufflers and resonators, i think it will make it sound raspy..not sure tho. its almost just worth it to buy the catback they have, and then you could have an exhaust shop make some test pipes for cheap
Old Jul 31, 2006 | 08:59 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
2nd. I wasn't gonna say it before, because some people don't agree, but there's a reason Specialty Z's exhaust is going to cost more... it's better. The craftsmanship wil be better, the fitment will be better, and the horsepower gains will be greater. Don't try to reinvent the wheel, just get the good product to begin with.
Old Jul 31, 2006 | 09:35 PM
they dont look any different then what a good shop could do, just get mandrel bent instead crush bent, but for almost $800 your local muffler shop could do the same for propably less..
Old Aug 1, 2006 | 06:35 AM
well...i still say buy an X or H pipe and then mabye get a section made back from there, with out that good X or H pipe your car sounds poopy, i would know from first hand experience.....mine was an individual exhaust all the way from the motor back, sounded extremely raspy.
Old Aug 1, 2006 | 12:01 PM
yea, the x/h pipes do look pretty damn good.
Old Aug 5, 2006 | 05:08 PM
KevinH's Avatar
I went with 3" custom exhaust system from the down-pipes back. I had the pipes mandrel bent and installed Flow Master American Thunder mufflers. I orignially did not have the cats put in, but considering how loud it was inside the car, I sent back and had some cats installed. I have the resonators, cats, and mufflers, though no X pipe or H-pipe. Not have having the cross-over has helped me in anaylizeing problems. You know when one bank of cylinders are not performing by the sound of the exhaust on that side. There are some advantages of not having the cross-over. BTW - the hp gain with this exhaust system was significant. You could physically tell the difference. No dyno specs.
Old Aug 5, 2006 | 11:49 PM
yea that is true with the diagnosis help.....but i still disliked the sound it was soo rough.
Old Aug 6, 2006 | 01:29 AM
X and H pipes exist for a reason, Nissan and every performance exhaust company didn't just put it on the Z for the hell of it... it causes a scavanging effect. The exhaust pulse from one side will cause low pressure in the other pipe, which will draw more exhaust gas out of that side. And if you're misfiring, you can figure out which cylinder is causing it by pulling off coil pack connectors, so please don't use that for justification as to why you don't have an X or H pipe. There are no real benefits from not having it, sorry.
Old Aug 6, 2006 | 08:54 AM
i also knew that, which is why i tried to hunt for a used exhaust for 3 months but every deal i worked out dissappeared into thin air, the a$$ holes on some places. then i ended up selling the car, but it was probly for the better, now i take my money save more till next spring and decide on what to buy.
Old Aug 10, 2006 | 01:30 PM
Barry'Z(NJ)'s Avatar
General Z User
See this thread >
https://www.zdriver.com/forums/300zx-z32-performance-technical-47/my-new-exhaust-17709/
Reving in the driveway >
http://www.askthedrunk.com/kenny/ztuff/100_1658.mov
And a fly by too >
http://www.photodump.org/stored7/barry6.wmv
lightspeed
Sep 30, 2010 06:28 PM
chicopriest
Sep 7, 2006 05:02 PM
markmbsc
15
Apr 27, 2006 09:48 PM
tsefreeflow
Jan 2, 2006 10:43 PM
SpeedFreakTom
34
Jun 18, 2005 09:09 AM
