crazy squeek that needs to go.
Subscribe
Jan 8, 2006 | 10:23 PM
ok it sounds like its coming from the front right side...or in the front in general, i have no clue what it is...but its making me crazy. its this like rattl squeek sorta thing and its from road vibration and bumps. does anyone know what this could be? i thought it was my crappy shocks when it first started, but those have been replaced with kyb gr-2's and that annoying squeek is still there.
Reply
Jan 9, 2006 | 12:15 PM
It is probably your hood. When you pop the hood there is one black rubber thingy in each front corner. Twist it counterclockwise so that it comes out a little more. That way the hood can rest on it.
Reply
Jan 9, 2006 | 12:38 PM
I had a squeeky problem like that and it turned out to be my bumper, it had come a tiny bit loose and was rubbing against the body
Reply
Jan 9, 2006 | 03:21 PM
i thought hood to i adjusted it...come to think of i...it did seem differnet...b4 it was super loose..i should go double check that
but yeah i already screwwd out the bumpers on the hood, im not that like....un-informed, just kinda...disty, or screwy at times....
Reply
Jan 10, 2006 | 02:19 PM
well....it was the hood bumpers..i screwed them out a little more thatn half a turn they came out..oops..but just a cm of threak in each side, now the hood is tighter and the squeek only happens when its really cold like this morning...but didnt do it this afternoon on the way home from school. i guess problem solved
Reply
Jan 10, 2006 | 06:07 PM
Yeah, these cars react to temp changes all the time. I have been having a problem keeping the hood bumpers to stay up. After every 100 miles I'll hear that sound and look under the hood, and sure enough, the bumpers found their way down again. It is really getting me mad. My n/a does the same thing, but it takes a year to do it.
Reply
Jan 10, 2006 | 10:57 PM
Huh....I've been getting the same noise it would seem every once in a while on the way home from work. Usually right as I'm rolling in to teh last 2 miles from the house I get this crazy creaking noice like my car is suddenly built of old wodden bridge parts. Comes from the left front right behind the windshield so it would seem to be the same hood bumpers yall are talking about. I'll check em
At any rate it isn't the suspension, I've check that.
Reply
Subscribe
