Coolant leak!!!
Old Aug 13, 2005 | 07:15 AM
oldschool's Avatar
Coolant leak!!!
I have a coolant leak and I can't find the source. The coolant is driping by the passenger side. I've checked the radiator hose and radiator and it was ok. I put the car on the lift and saw some coolant residues by the passenger side but I still can't find were it's coming from. The leak is not severe but it slowly lowered my coolant level. Where else can I check for coolant leaks.
I have a 90ZTT auto.
Old Aug 13, 2005 | 09:59 AM
Fast240Z's Avatar
check your water pump on the front cover of the motor, as well as the front cover itself.
Old Aug 13, 2005 | 10:41 AM
NA300zx_2005's Avatar
sounds like you've got a slow leak, i'd go to the local parts store and purchase a small bottle of coolant dye. then drive it around for a couple of days and then check everything over with a UV light. if theres a leak, thats worth worrying about, you'll see it.
Old Aug 15, 2005 | 10:40 AM
really the proper way to test it is to use a cooling system pressure tester. I'd use that as well if you can gain access to one.
The_MuffinMan25
Oct 23, 2009 08:42 PM
emann029
Jul 28, 2009 11:27 AM
duowing
Sep 21, 2005 07:23 PM
zfanman
Jun 24, 2005 01:56 PM
quansta
Nov 20, 2002 09:35 AM
