Clutch Problems, need help
Old Mar 6, 2006 | 07:09 AM
Brian's Avatar
My clutch pedal went down about 3/4 of the way before it engaged then you could hardly shift at all. I got out and checked the fluid and it was empty, kinda strange since it drove fine the day before. I have also been hearing a sound when it's idling and the shifter is in neutral. The sound is like a scraping sound and no doudt it's spinning, it stops when you press the clutch. The sound is coming from the shifter area. I filled it up with fluid and drove it home it worked ok and improved as I drove. But, I don't know why the fluid was empty I saw no signs of a leak on the garage floor. 1993 300zx convertible 58,000 miles.
Thanks.
Old Mar 7, 2006 | 05:04 PM
Goofyz's Avatar
that's odd
clutch fluid is the same as brake fluid isn't it? if it is...and you leave it overnight im pretty sure it wont leave much if any of a puddle. Check your gasket around the piston on your slave cylinder located under the car mounted on the tranny its the piston that actually makes the clutch ingauge, its probably leaking pretty badly. I say this is probably leaking cause its a rubber gasket and where its situated makes it prone to damage, its also the lowest point in the system so if its going to drain to nothing...usually its from there.
Old Mar 7, 2006 | 06:00 PM
japanz's Avatar
"...scraping sound and no doudt it's spinning, it stops when you press the clutch..."
Sounds like a throw out bearing but something is very seriously wrong and you should get your car into a shop. Luckily a MT is lighter than the AT and there is a lot less to remove to get it out. Have you ever heard of critical mass? It will teach you the hard way if you don't get into a shop ASAP and get the issue fixed. A repair is cheaper than the whole rebuild if you really mess something up. Point being something is terribly wrong when you hear metal on metal and you should not wonder anything. Get it fixed.
Old Mar 7, 2006 | 06:29 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
The slave cylinder commonly goes bad on the Z32. It's $28 and will solve the pedal pressure issue (by the way, while you're down there, I HIGHLY recommend Coz's stainless steel clutch line... makes a huge difference in pedal feel).
As for the sound, listen to japanz
Old Mar 7, 2006 | 07:12 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Confirm that it's the slave cylinder that's leaking.If there's no puddle but you're still leaking clutch fluid, it's the clutch master cylinder not the slave. The missing fluid is probably leaking into your car rather than outside to the floor. In that case the seal of the master cylinder is gone. You'll either hafta rebuild it with a reuild kit or just replace it altogether.
Old Mar 8, 2006 | 11:59 PM
Goofyz's Avatar
Ah YES!
That stainless steel clutch line does make a difference, its great, i noticed it after the car is warmed up the pedal feel never changes unlike stock rubber (even in warm weather).
Old Mar 9, 2006 | 12:24 AM
Mousier158's Avatar
Steelbraided for life!
Agreed, steel braided clutch line is the ****. However, CoZ's 10" steel braided clutch line wont give you much difference. you still have the clutch booster/assist that softens the pedal. That was nice about doing auto=>5spd convertion...I removed the useless stuff like HICAS, EGR (shh!), A/C...
Old Mar 13, 2006 | 02:58 PM
silvrhand's Avatar
Snazzy Title
As in you push down and can't get it in gear, or you let out and it won't go anywhere? Was it working before or did you have slippage and now this? Any burning sounds, clunking, anything like that?
Be descriptive as you can please.
Originally Posted by Pot_Head_Golfer
I have a 1993 300zx 2+2. When the weather is cold outside, the clutch will not engage. Anyone has any ideas?
Old Mar 13, 2006 | 03:18 PM
RodMoyes's Avatar
Doesn't post much...
Originally Posted by silvrhand
Any burning sounds...?
Uh... What exactly does a burn sound like?
Rod.
Old Mar 13, 2006 | 08:58 PM
Rod.
you know....like the sound of hotness....opposite of coldness sound...duh?
Old Mar 20, 2006 | 02:30 AM
Mousier158's Avatar
This should solve it...
Could be a number of things but i would try to readjust the clutch pedal using these steps.
http://www.specialtyz.com/clutchadj.htm
87_silverz31
Apr 7, 2012 10:56 AM
cockerstar
Jun 6, 2008 09:37 PM
FairladyZ84
Feb 21, 2006 10:33 AM
Darius
Oct 14, 2005 09:04 PM
hndah8r
Aug 15, 2003 09:24 AM
