Chipping my N/A
Old Jan 28, 2004 | 12:55 PM
91zxtt's Avatar
300 HP is not easily accomplished for the N/A. A full exhaust system would help, and should be the next step prior to the chip. Check out www.specialtyz.com. They sell some really nice stuff. They have many options for different emmissions standards. I have no idea what the UK requirements are, but you'll find what you need here. If you can get rid of the CAT, then do it. After the exhaust system you should install the chip. Most people on this site, including myself will recommend the ashspec chip available at www.z1motorsports.com. The performance gains are greater than the competitors. The price is approximately 1/2 of what you'll pay elsewhere, and it's safer for the engine. You could install an underdrive pulley set, but the gains are less than 10 HP. www.unorthodoxracing.com. You could also go with a lightened flywheel and driveshaft, but once again, you'll see minimal gains. Give Z1 motorsports a try again. You can go with the extrude honed upper and lower plenums, but you don't get much bang for your buck here either. These items should get you close, but will probably still leave you short of 300 ponies. Hope this helps. Good luck.
Old Jan 28, 2004 | 02:33 PM
emo236's Avatar
confuzed member
Well, accomplishing 300 hp to the wheels is a lot different than to the crank. The TT has 300 to the crank. The biggest thing you can do after exhaust, chip, etc. is gonna be nitrous. You'll get the biggest bang for your buck with a safe nitrous setup. Also, with all the power..the OEM NA clutch won't do. Get a lightened flywheel and an RPS clutch. Here's a list of sites that you can go looks for decent mods for your NA.
http://conceptzperformance.com/
http://www.boost-solutions.com/
http://www.splparts.com/
http://www.z1motorsports.com/
http://www.sgpracing.com/
http://www.turboclutch.com/
http://www.unorthodoxracing.com/index1.html
http://www.nitrousexpress.com/
http://www.jimwolftechnology.com/
http://www.bbtriflo.com/
That should be a good start for you to start shopping around. There's more out there, I just don't have time to find every shop for you, but here's some good ones.
Old Jan 28, 2004 | 07:10 PM
91zxtt's Avatar
If you do everything I listed, you'll get close. Cams would push you just a shade over 300. Nitrous will give you an extra 50-75 HP, but you obviously can't use it all the time. You can get cams from many af the sites Emo listed. The cams would be by far the hardest job.
Old Jan 28, 2004 | 09:19 PM
emo236's Avatar
confuzed member
You could always get creative and bore out the block....or drop in a vette 350 (it's been done).....hey, it's still an NA... JK...but you could bore or do a bunch of head work (i.e., 5-angle valve job, port and polish, etc.) And then, you might get there. For goodness sake, if all they sell are TTs, sell your NA for a lot since it's "rare" and get a TT.
Old Jan 29, 2004 | 10:56 AM
emo236's Avatar
confuzed member
Definitley keep us updated. But, not to discourage you, but good luck keeping up with the TTs. Even if you do get up to their level, all they have to do is dump 2 grand and they'll blow you away again and you're out of mods to do. And I have a TT as my daily driver, it's always on the road. And the only problems I've had are non-turbo related (i.e., clutch slave cylinder, hesitation, etc) But, to each his own, at least you're unique up there...but keep us updated, it's still impressive to see a fast NA even if tehy can't keep up.
Old Jan 29, 2004 | 12:38 PM
91zxtt's Avatar
Actually if you can get your N/A to 300 HP, you should be quicker than the stock TT's. You have better gear ratio's in the rear-end for quick take-offs. They'll be able to run you down, but you'll jump out early.
Old Jan 29, 2004 | 01:55 PM
Z_WRECKER's Avatar
+ n/a weights less tt's are fat hahaha....sorry guys... i just can't wait until i swap my tt....my precious...all mine... i am losing my mind... i haven't slept in last 2 nights
Old Jan 29, 2004 | 02:40 PM
emo236's Avatar
confuzed member
Yes, you can. So you'll beat up on stock TTs, but good luck on modded TTs. Zwrecker, you're car will be a drag car when you get the TT swap done since you allready have the closer gears.
Old Jan 29, 2004 | 09:05 PM
Z_WRECKER's Avatar
watch out emo, bc if i have any money left i am gonna take a road trip accros the country...just kidding man. i know, i just want my Z to run good... i wanna keep her forever, so the engine swap is gonna be her new heart and soul, and she's gonna be my weekend ride. my dad said when i graduate from college he'll get me a 350.... i just talked to him today.so in a couple of years i'll be set. actually he's been begging me to sell my z and that he will help me buy a newer car, but i just love my z32....i could never sell her
Old Jan 30, 2004 | 11:58 AM
emo236's Avatar
confuzed member
Most can get it to about 180 or 190 to the wheels stock. Some maintenance sounds like it could go a long ways to help you out. At the crank it's 222 bhp.
Old Jan 31, 2004 | 01:46 PM
emo236's Avatar
confuzed member
Stuff like PVC vlaves, stuff like that...here take a look at this:
http://twinturbo.net/ttnetfaq/FAQpages/pep.html
http://twinturbo.net/net/viewmsg.asp...&msg_id=813994
Old Jan 31, 2004 | 03:23 PM
emo236's Avatar
confuzed member
It's all in my head. I just see questions people have and it reminds me of something else I read or have done and used a certain link to help myself. I'm just glad I could help you out. But after you do that stuff, see if it seems to make a difference in performance.
Old Jan 31, 2004 | 07:03 PM
91zxtt's Avatar
It's actually a PCV valve. PVC is that white plactic tubing. PCV + Positive Cranckcase Ventilation. It's not exactly a fun job, but could help. The voices in Emo's head tell him what to do. Tune ups include basic things. Spark plugs, fuel filter, air filter, clean throttle bodies, etc. You really have an automatic!?! Might I ask why? I always think it's a shame to have an awesome sports cars with an automatic.
Old Jan 31, 2004 | 08:14 PM
Z_WRECKER's Avatar
i know... i just love listening to my Z going trough gears, and my g/f can hear me coming to pick her up since her road is full of curves, and i push the car to the limit, so she can hear me abusing the tires ...good old days of having my lisence....9 more days sorry i know i've been talking about this, but if it ever happens to any of you ( which i hope it never does) you'll know how i feel........NEEED MY Z.....ROAD....FAST
Old Jan 31, 2004 | 08:15 PM
Z_WRECKER's Avatar
man you need to sell your Z and get a 5 speed TT....i wanna a TT
Old Jan 31, 2004 | 09:08 PM
emo236's Avatar
confuzed member
oops sorry, that was a typo. I meant PCV. Anyway, zwrecker, we went over this. The guy wants to be completly unique b/c theres a lot of TTs and hardly any NAs where he lives. I don't understand it either, but to each his own.
Old Jan 31, 2004 | 09:43 PM
Z_WRECKER's Avatar
i know i know.... i used to want to have a kick *** n/a...(which i do ) but then i saw how much more power you can get out of a TT. well then at least he should get a 5 speed. Now i just can't wait to get my TT. every day that passes, i am a day closer
Old Jan 31, 2004 | 10:02 PM
emo236's Avatar
confuzed member
Have you considered doing a manual tranny conversion? You'll get a lot more power to the rear wheels with a manual tranny setup. If you're gonna spend all this money to make a fast NA, which you will, the conversion would be pretty worthwhile.
