Chemical cooling
Golly Mr.ZeroPositive, go tell that to the refinerys that put blue, green and red dye in gasoline to distinguish the different grades of gas, so the people won't make a mistake in the grade of gas it's not good for the engines.
And while your at it tell everyone about the phone conversion (lier) we didn't have.
Keep digging the hole, your easy to bury.
Mr.CC, the first post has a website that has some good information in it, but remember it was written by the people that sell injection systems and the'll lean toward there product.
As for only getting 5% gain on a N/A engine thats kindas true and not true. I'll explane. Example: when you run a large load of nitrous you have to retard the timing, but if you run water/alky injection no need to retard the timing. You can run higher compression pistons with a lower grade gas as water/alky increases the the ability to do so by lowering the combustion temps. thus reducing the chance of detonation. Claims are but don't quote me, you can get a 60HP gain using Water/alky injection if done properly.
I do know that the F-51 aeroplane used what was called ADI (anti-dentonation-injection) for high power combat settings.
I don't think if it was unsafe it would be used in aircraft, and if it didn't have merit I don't think they would have used it. Germany was the first to use nitrous and water/alky during the 2nd war and the USA had to do a catchup game to get there planes to go as fast as the Germans.
Do they work, well I know of a N/A Z32 that runs a 450HP shot of nitrous and water/alky and runs pretty quick. You be the judge.
Originally Posted by 91zxtt
..........Were you abused as a child?
Zgringo, yeah I went to that website and found the info interesting. (even dyno charts, evan). This would be something I'd try tinkering with at a time when I was going to do a dyno run. Which I've never done yet myself. I do like the idea as an aid to being able to run higher compression ratios.
Originally Posted by CanyonCarver
ha ha ha, He's definitely got low self esteem. He's probably got a big brother that beats up on him, or there's an alcoholic parent somewhere in his closet. I just had to respond to that one.
Either that or someone's still in the closet.
In considering our fellow man, we should always remember some have good points and some not so good. Just because a few are no good SOB's doesn't mean their isn't some good in them. We just have to find it.
God loves us all.............I think
Mr.CC, FYI the last time I run I was behind a Vette by .05 sec. and had to make up some time.
I changed my Water/alky from a 75-25 mixture to 50-50. changed my 2nd stage nitrous jets from 150 to 250, ran my boost from 20# to 24#, never touched the timing, and made my fastest pass ever with that car and beat the Vette by .02 sec.
Gotta go back and do some homework as I melted 4 electrodes on the plugs, so I was getting close to disaster. I think if I run alittle more water/alky it well cure the problem
okay, Evan, i know a LITTLE about car fuel adatives and basic chemistry, if i recall correctly, Ethanol alcahol is the main ingredient in dry-gas to make the water in teh fuel soluble, so that it will mix with the petroleum products and burn with the gas... so im gonna go out on a limb here and say that the ethanol is added to the water so that when it enters the combustion chamber it will combust as opposed to hamper the combustion of the fuel, just a guess....
Originally Posted by Zgringo
I'd be more than happy to explain Mr. Tangeray. I couldn't find a MSDS for just window washer as different mfg's. have differend was to make it, but this company, Sprayway Inc. had a MSDS listed that is packaged in a aerosol can. Because of the gas thats used for expelling the window cleaner has added warnings listed for it. I have 2-1gallon jugs that list water and methanol and thats it.
Below is a answer to the question of using from one of the compants that sells injection kits.
Originally Posted by 732tt
he never said he used the cans.
Originally Posted by 00Evan
Go dump some window cleaner in your engine...
"dumping" window cleaner would have the same effect as "dumping" gasoline into the engine. That's what is known as flooding.
I believe that the delivery of the water, ethanol, methanol, nitrous, or other air/fuel additive is the key to it's success.
......Gotta go back and do some homework as I melted 4 electrodes on the plugs, so I was getting close to disaster. I think if I run alittle more water/alky it well cure the problem
Do you run any EGT guages? It seems like it would be a good way to tune the system, tied of course to afr's.I'd say you're lucky on the plug electrodes. I had the center electrode come apart one time and it bent an intake valve and broke an exhaust valve on its way out.
Oh yeah, I'll re-reiterate, the alcohol in the window cleaner is to keep it from freezing.
Wait a tick.
Did anyone else notice Zgringo is supposedly using a product that comes in aerosol cans for his injection? How the **** does that work dumbass, do you spray the cans in the intake like nawwwzzzz!?
So will you go to a larger orifice in the injection system or try increasing the pump voltage? The orifices in the kit look kinda like plain old carb jets and the pump looks like a walbro (or equiv.) fuel pump.....
I have dual EGT's and dual wide band o2's and it makes setting the A/F a snap.
As for being lucky with my plugs, thats the under statement of the day. Nothing broke off, just melted, telling me things got pretty hot in the combustion chamber. I've since backed off on the boost and nitrous till I get this problem solved.
And your right, the alcohol is there for nothing more than to keep the fluid from freezing
Someone needs to do some research (00Evan).
You need to start reading the articles on the injection kits and testing. You can start on Google. Lots of info there.
It has been proven that a mixture of water and methonal or alcohol provides better results than running either straight.
I also use windsheild washer fluid in my system. No problems at all. Lots of people use this. It has been proven to work just fine for years with no problems.
The little amount of soap in the windsheild fluid also acts as a lubricate for the pump. Another plus.
I don't need any scientific info here, I'm using real world testing results and hands on testing results.
First things first :)
Would you be as so kind and tell us how you came about using automotive window cleaner?
I think you need to stop saying "automotive window cleaner". I think you are confusing some people into thinking you are using the aerosol spray glass cleaner that's in a can. It's windsheild washer fluid, the blue stuff that comes in a jug that you pour in. At least I'm assuming that's what you are using (as well as I and others).
I started using the washer fluid more because others have been doing so for some time now. I read the benefits of it's mixture is a few articles in my searchings on Google. It's also easy to get, you can use the same container thats in the car already if you want, and it's cheap. And it's already mixed and ready to go. There are lots of scientific write ups and such out there that show why the mixture does a better job at cooling the charge than a straight mix of just water or alcohol. If I remember correctly it's about the way it effects the charge during combustion. The water has a certain flash off point, and then so does the alcohol/methonal. So by using both you get a wider range that the fluid effects the combustion process. If you just use one or the other it will burn off all at once at once certain temp. Don't quote me on this, it's been awhile. Lol.
I'll see if I can find some of the articles I read back in the day and I'll post up the link.
Good supporting info woody, what kind of rims are on your car?
I'm gonna go out on a limb here, so be nice evan. I haven't done a google search because it's not that important to me.................... but, if you've heard of oxygenated fuels (during the winter in cali) they add ethanol/methanol to the gasoline to make your car run leaner. The idea being that these alcohols have an extra oxygen molecule that leans out the combustion process. My point being that with water/alky injection, if you could time in more fuel, you'd make even more power............. Just a thought.
Thats the idea behind it CC. You can run more boost and or nitrous without having to retard your timing and losing power.
Woody, I only used the term Automative window cleaner as I didn't want to confuse it with household window cleaner, but it is called automotive windshield washer fluid.
You are correct in you assumptions. Once thing to keep in mind though. If you just add fluid injection and don't change anything else it will not help you and in some cases has shown to actually hurt power. To get the benefits of it you need to raise the boost level and/or timing. Pretty much the same things you do when running race gas.
They are 5Zigen Copse. 18x8 and 9.
Someone explain where you add this "washer fluid"? is it to the gas tank? do you have to create a stand alone injection system like a water mister? or do you add it to the coolant?...im very interested.
~~Tangeray
~~Tangeray
Originally Posted by tangeray
Someone explain where you add this "washer fluid"?.....
http://www.snowperformance.net/
