can car run without pcv?
Old Mar 23, 2006 | 09:45 AM
jammer300zx's Avatar
can a 91 300zx run without driver side pcv valve?
Old Mar 23, 2006 | 10:44 AM
CanyonCarver's Avatar
Jack Of All Trades
You'll have a vacuum leak if you don't plug the whole in the intake plenum. Without the pcv valve, you chance blowing oil out of your crank and cam oil seals.
Old Apr 6, 2006 | 07:40 PM
Mousier158's Avatar
if you plug the PCV vavle ports what CC says may happen, but if you bypass the PCV system with a blow by canister/ catch tank you will be fine.
Old Apr 6, 2006 | 10:15 PM
jfairladyz's Avatar
I wouldn't recommend removing the PCV. Even with a catch tank. There is absolutely NO benefit what so ever from eliminating the PCV valve. You only seek to complicate things by doing so. A catch tank system requires more space and plumbing then the PCV system and you can't just seal the PCV up cause you'll be blowing seals, as was mentioned above. If the valve is bad just replace it. They only cost a few bucks
Old Apr 8, 2006 | 08:28 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
... bingo...
Old May 8, 2006 | 01:09 PM
WhtFairLadyZ's Avatar
Well I know when I bought my RVM hard pipes I was forced to elimintate the front two PCV tubes due to fitment. The rear two coming off the plenum are still in place. So I dunno if what effects eliminating just two would have?
Old May 8, 2006 | 04:46 PM
jfairladyz's Avatar
worst case scenario you atleast want the crankcase to be able to vent when the pressure builds. But with the PCV in place the pressure is actually sucked out, creating a vacuum which helps to not only evacuate the pressure but also helps to seal the piston rings and reduce blow-by.
