Bee-R rev limiter install
Hi everyone,
Im trying to install the Bee-r rev limiter in my tt Z but im having some issues getting the rev to bounce. The device is reading the information from my tach but not bouncing when i set the rev. If someone is running this units could you please give me some info. I've looked every were on the web and cant find anything ...... Thanks |
Originally Posted by vaderZ
(Post 300444)
Hi everyone,
Im trying to install the Bee-r rev limiter in my tt Z but im having some issues getting the rev to bounce. The device is reading the information from my tach but not bouncing when i set the rev. If someone is running this units could you please give me some info. I've looked every were on the web and cant find anything ...... Thanks You realize that bouncing on a limiter will actually harm your motor right? Also if you had a reason to actually bump the limiter, then you would already have a tuneable ECU and would be able to set the limiter. |
Do you know what the Bee-R rev limiter is? If you did you would know that its a launch control that allows you to set a rev limit at your desired rpm for ex. 3K and it will allow you to launch at boost. You dont use the factory rev limit there for your your engine will not be damaged cause it cuts ignition not fuel. Sooooo again if there's any one ACTUALLY currently using this unit could you please share some wiring info with me.
(Post 300463)
If you want real launch and traction control system, look into the racelogic TCS, or look into integrating the q45's TCS and tune it. |
| All times are GMT -7. The time now is 01:41 AM. |
