5 Speed vs. 6 Speed
Well the gears have nothing to do with the horse power your engine is putting to the flywheel... On the other hand you would more than likely see a higher top speed with 6 gears, and maybe a slightly better acceleration due to the likely closer ratio of the gears in general. 5 speed has seemed to work great, I have had a 5 speed in all my cars... I don't even know if you could attain a 6 speed transmission for a z32 without some decently major mods either. Just my 2 cents.
well, changing the transmission is just gonna put your gears closer together. Not really change your exceleration, besides 6spd in a Z32 is gonna cost you a pretty penny for something that really won't do too much for ya.
I've never seen a 6 speed in a Z32. You would have to re-configure the entire gearbox since reverse is stacked on top of 5th gear. There's nowhere to put 6th gear. You'd realize minor acceleration gains, if any. Yes, the gear ratios are closer, but you'd lose time with an extra shift. You'd see more benefit in driving up hills and through multiple corners. It's less likely that the engine will bog down.
Originally Posted by FleagoZ32
Don't the Z33 with VQ35 lump have a 6 speed box? If so, could this not be made to fit the Z32's?!
There's a 6 speed tranny that works with the vg30. It's extremely expensive and needs alot of work to install. Not worth it in my opionion. For the price of this tranny alone, you could almost buy a used Z33. Unless you've got G's to burn, concentrate on other aspects of the car.
thetorp
May 4, 2016 05:39 PM
bluesman1958
Apr 15, 2004 03:31 PM
