1993 Nissan 300zx Na to Tt swap complications
Old Mar 24, 2018 | 04:11 PM
Jamison Gleich's Avatar
If anyone could help it would be awesome. I bought a 1993 Nissan 300zx NA 2+2. I did a full tt swap. I am having trouble with it. The car will start every time, it will idle for hours, but it will not rev over 4000 rpms. I have bought new sensors, but still have not gotten a change. I have 2 or 3 mass air flow sensors, 2 or 3 tps sensors, I have replaced several parts. But still cannot get it to run over 4000 rpms. I checked for codes on the ecu self diagnostic and it reads code 42, I have replaced the fuel temperature sensor and also the the wire connector itself, it reads 14 volts, but I still have the code. I will post links to 2 videos showing the car having this problem.
Old Apr 8, 2018 | 10:46 AM
zleeper's Avatar
Did the exact same swap
One thing I overlooked when swap was going with TT fuel pump. It runs out of fuel at top end. To do this you will have to run a wire to your ecu. There is tt wire from pump to under the dash but it ends there in 2+2.Oh yeah. You have to have tt ecu too. Hope this helps.
zleeper
Old May 22, 2018 | 10:24 AM
Barry'Z(NJ)'s Avatar
General Z User
zleeper
While you must use a TT (or some other upgraded) pump to handle the higher fuel requirements, you can run the TT pump with the NA controller. You just get two speeds/flow-rates out of the TT pump, high and low, rather than high, medium, and low, that running the extra wire and TT controller will yield.
mach1racer
Oct 22, 2008 08:26 PM
NewZMan
Aug 20, 2008 05:00 PM
nismo619
Jun 27, 2008 10:29 PM
Okaii.Bye300zx
FS: 300ZX (90-96)
Mar 29, 2008 07:39 PM
