Turbo Question
Old Apr 21, 2013 | 05:11 PM
Larkin300zx's Avatar
Turbo Question
Hey everyone whats up! So i have a 91 300zx w/ 78k miles and the car originally was a automatic and then they switched it over to a manual. Now Both my turbo's blew and im about to buy a new pair of OEM's but its asking me if i want (manaual) or (auto) turbo's? Im not 100% if the guy switched the turbo's over when he did the tranny?
Either way im just wondering what type i should buy since my car was both. Thanks for reading and helping guys!
Old Apr 21, 2013 | 07:53 PM
PredatorZ's Avatar
A/R trim
Each of the Turbo types were dialed in for the transmission used, they should interchange mechanically, since you are now running a manual, I would assume you would want the turbo biased for that application, although I bet either would work.
M/T cars had turbos with an A/R trim of .63. A/T cars, .54.
A larger A/R will spool later and provide a higher power band.
Probably the lower A/R on automatics was used to help the auto spool a little faster and keep the rpm's lower to protect the engines from over revving on shifts. My best guess, I am by no means a turbo expert, so if anyone can shed more light on this please chime in.
Old Apr 26, 2013 | 09:47 PM
Hey just to let you know i contacted the guy and you are right the manual put's out more A/R but since the car was an automatic to begin with i think thats what i need either way i could get either but just to be safe
Old Apr 26, 2013 | 10:06 PM
PredatorZ's Avatar
To be safe
I would get the proper one for the transmission you currently have, the auto is long gone, Nissan did the research for a proper fit, form and function, I would rely on they're R&D, go with the manual version.... to be safe.
Old May 2, 2013 | 09:38 PM
vuez32's Avatar
Keep in mind that your engine is still from an Auto TT. This means you have lower duration cams which will effect spool up and power band. I don't recommend rebuilt OEM turbos, they don't tend to last very long. I would at least get Z1's GT535 Kit as a replacement as your talking your engine out anyways.
one_fast_300zx
Oct 22, 2006 01:14 AM
deedee
Jul 14, 2005 02:03 PM
ZWatcher
Aug 23, 2003 04:33 PM
z17
Sep 7, 2002 02:57 PM
Simonissan
Jul 20, 2002 05:50 PM
