tires/seats
Old Feb 4, 2009 | 04:23 AM
rtmorgan's Avatar
Obsessive Craigslist Disorder
tires/seats
ok two things.
first off i got power seats in my slicktop now!! well driver side anyways.
this guy i found wanted to trade since he is pretty big and the non powered seats are slightly lower.
also i was wondering 17" or 18" ? i want to run as wide of tires as possible without rolling fenders or doing any modification what width will fit on the front and rear?
im pretty sure a 10" wide tire will fit the rear just fine and i was thinking mabe an 8.5-9 in the front?
oh what would the offsets need to be?
last but not least, do you think i should make my custom whees? i have access to a fully programable cnc mill at my school what you guys think?
Old Feb 4, 2009 | 08:41 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
having access to a CNC lathe is only half the issue... a block of aluminum (or really any metal used for wheels) large enough to make a wheel out of costs upwards of $1500 (easily). Your custom wheels would cost you at least $6000...
As for sizes, I recommend 17" over 18" based on decreased rotational mass. Whether you go 17" or 18" won't matter for fender rolling as long as you get a tire with a small enough sidewall (the goal of any aftermarket wheel/tire combo should be to have the same height as stock wheels so that you don't impact your speedometer). I recommend fronts that are no more than 1" narrower than the rears (to resist understeer), so if you're doing 10" rears, exclude 8.5" fronts. As for offsets... I was never an expert with knowing what offsets are best. When I have time later on, I'll dig out the articles on tt.net that I have saved about the matter.
Old Feb 4, 2009 | 09:13 AM
rtmorgan's Avatar
ok thats good to know on the width issue.
and the aluminum is not that big of an issue either.
my dad actually has 6 square chunks of it that measure 20"x20"x2"
well see what happens.
on the rears i was wanting to run a 255-275 profile tire and a 245-255 profile tire on the front or something along those lines.
ohh and i am going to test out my sewing skills and try to re wrap my seats in suede if its not that bad mabe i could do some for you guys
Old Feb 4, 2009 | 09:34 AM
rtmorgan's Avatar
ok scratch the wheel making he sold those pieces
Old Feb 4, 2009 | 11:35 AM
nzniggles's Avatar
20"x20"x2"
A 2 inch rim is pretty narrow too
Old Feb 4, 2009 | 12:09 PM
... sez yu...
Yeah, and I wouldn't recommend making your own multi-piece wheels anyway... (and even if you did, you'd still have to buy the rim itself so you could bolt in the face).
245 width will fit on an 8.5" wheel, 255 width would require a 9"
You can squeeze 255 width tires on stock 8.5" rears if you get them meaty enough (MT ET Streets that you see on cars like Dean Delvy and other 10 second cars with stock wheels are 255 width), so if you plan on getting a wider wheel, you might as well get a wider tire. I have 285 rears (I think) on my Z. But the aspect ratio is what's going to save you from having to roll the fenders. (Why are you against that, anyway? Nothing wrong with rolling the fenders... it's not expensive and it allows more clearance.)
You're brave... that's the one task I won't even bother attempting to do on my own.
Old Feb 4, 2009 | 12:18 PM
nzniggles's Avatar
... sez yu...
It is if you want to go over 6 MPH
Old Feb 4, 2009 | 12:32 PM
Quoth the Fresh Prince:
"every moment frontin and maxin
chillin in the car they spent all day waxin
leanin to the side but you can't speed through
Two miles an hour so everybody sees you"
Going slow is where it's at.
Old Feb 4, 2009 | 01:19 PM
rtmorgan's Avatar
yeah i might roll the fenders if needed.
what setup are you running front and rear on your car whels and tires?
oh yeah and the seat thing really doesnt look hard.
yeah i know it sounds gay but im really good at sewing.
when i do it im going to put in extra cusion too
Old Feb 4, 2009 | 02:49 PM
17x8 fronts and 17x9.5 rear (yes, I broke my rule... but I have really good tires so it's ok...)
I was wrong, my rears are 275. I could probably fit 285 though. Fronts are either 235 or 245, not sure of any of the aspect ratios.
Old Feb 4, 2009 | 06:41 PM
The_MuffinMan25's Avatar
Registered Drifter
I had 235 up front and 265 in the rear. Not sure what the rims width are but they are 17"
wals
Aug 27, 2009 10:14 AM
nismo619
17
Oct 30, 2006 07:17 PM
thxone
May 18, 2006 03:37 PM
petrol
Jan 13, 2006 08:20 PM
rupert42
Jun 25, 2004 08:25 PM
