RHD TT Fuel Pump Not Priming!
Alright, so I tried to wait until the bitter end of my capabilities to post, but I need everyone's help.
I have a 1989 (equivalent of a 1990) RHD 2+2 Twin Turbo. When it arrived it would not run, and obviously had a bad battery (actually checked it, and it was bad). Replaced the battery, and then it cranked but with no ignition. So I started with checking fuel, and realized the fuel pump is never kicking on (had someone stand with their head right above the pump to listen). I checked the power all the way to the pump (checking the relay, fuse, and the control unit behind the left seat panel), and power was getting to the pump. So, I concluded the pump itself had gone bad. I then bought a Warlboro TT pump, removed the pump from the car, swapped the pump out, and tried again. Still no prime. I obviously realize the original pump may have been fine, but it was old anyway (the car has 48,000 miles, and everything is pretty much stock). So, where do I go now? If it's a bad ground, where should I start? Is there anything I could have done wrong? (I also tried to check the sticky and researched a lot before posting this, so I apologize in advance if this has been a problem before.) |
Welcome to ZDriver!
Originally Posted by EliHellstrom
(Post 342412)
(Post 342415)
Welcome to ZDriver!
How many volts were at the pump? Have you tried a temp wire direct from the battery to pump? There's either no power / incomplete circuit, or dead pump. If you've verified that both pumps actually do work, then you have an incomplete circuit. Work backwards from there. I'm pretty confident the new pump works, so I'm assuming it's an incomplete circuit. I tried to bypass the FPCU, but there was still nothing. I'm also going to try do that again today. What do you mean by a direct wire from the battery to the pump? Sorry if that's a dumb question. |
