Question N/A Vs. Turbo
Old Apr 26, 2011 | 08:24 PM
kazoku's Avatar
I have 1991 300zx i replaced my N/A intake manifold with my friends Turbo intake manifold and know my wont start i thought that buy switching it i should see power gains but ill i get is a free gun show of pop pop pop boom!!! trying to get the car to tern on before this mode my car ran fine.
Question
Should issue Hp gains or not with this mod?
Why wont the car start? What should i be looking for?
Old Apr 26, 2011 | 08:34 PM
BlueKitsune's Avatar
Intrawebz Wizard
I have no idea what you just said but I'll take a guess....
You trapped your cat under the intake manifold and it caught fire?
Kidding of course!
The N/A and the TT have the same upper and if I remember right the same lower intake manifold. the only difference was the Throttle Bodies and it wasn't that big a difference at all. If any
You would see more gains from a single popcharger air filter then an intake swap.
Also make sure you put the all the connections on correctly in the proper places sounds like you mixed up a few coil pack connectors.
Old Apr 26, 2011 | 08:45 PM
No difference between N/A and TT anything from the TB's to the heads.
Old Apr 27, 2011 | 03:41 PM
kazoku's Avatar
just found out my friend mistakenly placed the coil wier to the o2 mistakenly and the O2 sensor where the coil wier goes we just fixed it and still wont start did i kil the ecu or some thing?
Old Apr 27, 2011 | 04:33 PM
Intrawebz Wizard
You sure?
You could have mixed the knock sensor connector and the O2 Sensor connector.
Old Apr 28, 2011 | 06:55 AM
Woody75(Denver)'s Avatar
You sure?
Knock sensor and O2 are not the same size plug.
Knock and VTC are the same. 2 wire
O2 and coil are the same. 3 wire
Old Apr 28, 2011 | 12:27 PM
Intrawebz Wizard
Thats what I meant! Sorry!
one_fast_300zx
Oct 22, 2006 01:14 AM
deedee
Jul 14, 2005 02:03 PM
ZWatcher
Aug 23, 2003 04:33 PM
z17
Sep 7, 2002 02:57 PM
Simonissan
Jul 20, 2002 05:50 PM
