question about cma gears
I have a 91 2+2 and I converted it to twin one of my intake cam gears has gone bad I have one that is good but it is off of the other side of another turbo motor I have my question is .Are the two intake cam gears the same are the timing marks the same I put them together they look the same but I am not 100% sure so if any one knows for sure please let me know thanks
thats pretty much what I did but now when I try to get it in time it is always one toothe out on at least one gear I dont know if i miss counted cause I did like ten times its a new belt so I know it isnt to long
yea timingcan be hard. Start with top idle pull then across both heads then crank On FSM there details about how many teeth should be in which section. Just double check timing marks are in right spots and u will get timing right.
http://www.300zx.co.uk/cgi-bin/manua...fault&total=70
[QUOTE=Lanoi;278497]yea timingcan be hard. Start with top idle pull then across both heads then crank On FSM there details about how many teeth should be in which section. Just double check timing marks are in right spots and u will get timing right.
We'll I got the car in time it started for about 30 secs of course I just wanted to see if it would hit before I put it back together it started sounded smoth as to be expected concidering the turbo pipes arnt hooked up and the mass air wasent or about any thing on the front any way I dont know alot of the names of the sencors forgive me I cant spell lol the I guess its called timing controle on the exhaust cam on the driver side has wires that run to the other side of the motor that plug into a box I dont know what it is called but that box is getting very hot do you have any ideal what that means if so I would love to know thanks
