No Spark, No Start. Cranks fine, Fuel ok
Old Jul 22, 2017 | 04:52 PM
spec1sef's Avatar
[FIXED] No Spark, No Start. Cranks fine, Fuel ok
Started my car and moved it few feet and parked it. Came back after 1 hour and now it just cranks but no start. Tested spark on cylinder 1 and there is no spark. I smell fuel on Spark plug. I also hear the Fuel pump turn on.
Already checked 12v at ECCS relay white wire it's present. I have the version 2 PTU.
Read below how I fixed it.
Old Jul 23, 2017 | 07:10 PM
spec1sef's Avatar
ECU Pin 16 that leads to ignition relay was not grounding so the ignition relay was not closing so coils were not getting any voltage. I took the ignition relay out and jumped the pin 3 and 5 using a small wire and then tried starting the car and it started right away.
I also tried leaving the relay in its place and tried grounding the PIN 16 on ECU harness with ECU unplugged and the relay made clicking sound. So for some reason my ECU is no longer grounding pin 16. If you are troubleshooting keep in mind you should have 12v coming on Pin 16 wire. ECU grounds this wire to close the relay which in turns send the voltage to coils.
Old Apr 13, 2023 | 07:14 PM
Jessej's Avatar
where is the relay located and which one is it?
Old Jul 6, 2023 | 06:21 AM
bozz911's Avatar
the realy is located under the hood on driver side. the cover has label on it. I have no spark and i jumped the relay but still no spark and no ground from ecu orange wire on relay...has the new ptu. also had new cas. I am going to check continuity on the cas plug to the ecu. not sure what it is yet.
Gearhead63
Jan 2, 2022 08:55 AM
Blackbettytt
Apr 29, 2017 06:19 PM
hoov100
Oct 4, 2010 11:05 PM
BlueKitsune
Mar 3, 2010 04:03 PM
Creator
May 31, 2004 12:59 PM
