New style injectors
Old Mar 30, 2006 | 11:03 PM
91 300zx N/A's Avatar
New style injectors
I want to put the new style injectors in my 91z does anyone know what I need to do to complete this tack
Old Mar 31, 2006 | 03:46 AM
japanz's Avatar
Well deductive thought suggests if you need new style injectors you may need an FSM for information regarding that. In the meantime:
Lower Intake Machined for New style rails
6 x Fuel Rail to Lower Intake O-rings
New Style Fuel Rails
6 x New Style Injectors
6 x Upper and Lower Injector O-rings
6 x New Style Injector Clips
Harness connectors may shorten that route considerably.
Old Apr 5, 2006 | 05:23 AM
Mousier158's Avatar
What you need to do is not waste ur time
-my $.02
Old Apr 5, 2006 | 09:08 PM
Riz Z Speed's Avatar
Administrative Brown Guy
-my $.02
unless over half of your injectors are bad or your car was in some accident where the fuel rails were damaged, i 2nd Mousier. Don't waste your time or money.
Old Apr 8, 2006 | 08:27 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
While I somewhat agree, I also somewhat don't. The bottom line is, early style injectors are more prone to failure because of their design (I don't feel like elaborating, just seach for posts by Greg Dupree on 604Z.com if you want the facts, it has to do with the constant voltage applied to the earlier style ozidizing the additives inside the injectors causing them to rust from the inside), as compared to the newer style which are not.
If he's only replacing to go to the same size but newer style while his current injectors are fine... yeah, that's pointless.
If he's got dead injectors, it completely makes sense.
If he wants to go to larger injectors without worrying about failure and is going to replace all six anyway, it also makes complete sense to go to the newer style injectors.
dennys93na300z
Oct 15, 2014 10:05 PM
timinthehood
Oct 11, 2013 04:09 AM
hoov100
Oct 9, 2010 05:21 PM
KasbeKZ
FS: 300ZX (90-96)
Apr 4, 2010 06:36 PM
thetremendousti
Aug 14, 2008 09:42 PM
