manual conversion help please
Old Feb 27, 2011 | 01:32 AM
ben's Avatar
ben
hi sombody please help. ive had nothing but trouble with it. now ive finaly finished but its so sluggish in 1st gear feels like im pulling off in third ( which im not as ive checked) ha. any ideas on what it could be. thanks
Old Feb 27, 2011 | 01:37 AM
ben's Avatar
ben
i forgot
the gearbox i put in is an na my cars a tt just incase that matters
Old Feb 27, 2011 | 06:12 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
Edit: I got the diagnosis backwards. Thought you had a TT box in your NA, but you have an NA box in your TT.
Usually NA gears have a higher accel rate, so not sure what the prob. really is. Also, is your engine still TT?
Old Feb 27, 2011 | 08:17 AM
ZLover4Life's Avatar
Encyclopedic Knowledge
NA and TT transmissions are identical except for the bell housing. In the future, please use google to corroborate your response if you're not familiar with the car in question. (See my signature.)
Does the car behave properly in other gears?
Old Feb 27, 2011 | 10:53 AM
ben's Avatar
ben
response
yup its still tt the engine has only done 72,000 ks so its still like new. could it be dif ratios and do i need to get a manual dif? thanks
Old Feb 27, 2011 | 10:55 AM
ben's Avatar
ben
it seems a little slower but im not really going hard on it because i put a new 5 puk clutch in
Old Feb 27, 2011 | 01:49 PM
Again, the gearing is NOT different. (:::sigh::: If people would read my signature, I wouldn't have to repeat myself so often.)
You can floor it with a new clutch as long as the clutch is fully engaged; you just cannot powershift - that's why they tell you to take it easy. (If you let off the clutch too fast or rev too high during a shift, you can glaze a new clutch. But if the clutch is fully engaged, it's fine.)
Put it in second or third and floor it, see how it responds. Until you can say, with certainty, how it runs in other gears, nobody can help you. I suspect your engine is not running as it should, and thus it has nothing to do with the transmission but rather something you messed up during the conversion (or something just happened to start having problems after it).
Old Feb 27, 2011 | 07:55 PM
ben's Avatar
ben
sweet im taking it for a boost now and ill let u know how i get on thanks again
Old Feb 28, 2011 | 01:15 AM
ben's Avatar
ben
thanks for the help guys good news took it to a mate whos more clued up than me and its all sweet now. . . . . . drift time
Old Feb 28, 2011 | 05:47 PM
Care to tell us what it was?
P.S. You chose the wrong car for drifting.
Old Feb 28, 2011 | 05:57 PM
I think that depends on who is driving it, the z32 drifts pretty good but it's ALOT less forgiving then say a 240sx.
Old Feb 28, 2011 | 09:20 PM
ben's Avatar
ben
it drifts all good and it diffrent from the standard skyline, cef, laurel. it was a simple fix. kinda embarasing. the shifter had sliped down (out of the broken rubber suport) on an angle. then when itfelt like i was putting it in 1st it was slipping into 3rd... . . . . kinda explains y it felt like 3rd
borini63
Jan 21, 2013 01:52 AM
anderlinedr
Aug 6, 2011 06:11 PM
FreeLanceBum
300ZX Z31 Tech Tips
Jun 6, 2008 03:16 PM
adamjoh
Australia
Mar 24, 2003 10:37 PM
adamjoh
Nov 25, 2002 08:30 AM
