Leaky fuel line
Old Feb 21, 2011 | 11:27 PM
sidneyam's Avatar
Leaky fuel line
Hey guys,
I got my car up and running but I think I have a leaky fuel line because theres a strong scent of gas. Can anyone tell me which lines to check?
Old Feb 21, 2011 | 11:32 PM
All of the rubber ones that hold gas under the hood....
Old Feb 22, 2011 | 05:23 PM
ZLover4Life's Avatar
Encyclopedic Knowledge
Originally Posted by hoov100
all of the rubber ones that hold gas under the hood....
+1
lmmfao.
Old Feb 22, 2011 | 10:52 PM
sidneyam's Avatar
Can you be a little more specific like where the location of the fuel regulator in this car
Old Feb 22, 2011 | 11:22 PM
fallow the fuel line from the filter to where it goes into the fuel rail and it's right there. I wanna bet that it's te little line tat connects the fuel rails.
Old Feb 23, 2011 | 01:53 PM
xpwarrior's Avatar
Actually when you follow the fuel line from the filter to the rail you get to the pulse damper first. The pressure regulator is at the other end of the fuel circuit where it goes to the return line.
Sidneyam here is a link to a diagram of the fuel circuit.
http://www.courtesyparts.com/300zx-p...3_900_902.html
Old Feb 23, 2011 | 02:23 PM
You wanna try that again? The fuel goes from the fuel pump, to a dampener to the filter to the FPR, to the fuel rail, to another dampener and back into the tank. You wanna know how I know? Because I spent two weeks of my life going through the fuel system on the TT from top to bottom.
Old Feb 23, 2011 | 02:54 PM
xpwarrior's Avatar
22675M is the damper and is the next component after the filter. Filter -> Damper -> Rail -> Other Rail -> Regulator -> Tank
Old Feb 23, 2011 | 03:47 PM
That's not how mine has been hooked up. Still runs great though
Old Feb 23, 2011 | 06:02 PM
The regulator should be the last thing in the circuit before the return to the tank.... that's how it works. It closes and opens, limiting how much is released back into the tank, to regulate the pressure.
Old Feb 24, 2011 | 02:40 AM
That's funny, my fuel pressure regulator on my 280zx, does exactly the same thing. And is the last thing, before fuel goes back to the tank. So they pretty much kept how the fuel was processed. Just added quite a bit more technology since my Z model.
Mine goes fuel tank, fuel damper, fuel filter, in to the rail, out the regulator, and back into the tank.
Anyway, I never really thought real hard. As to how the system was set up the way it is. Now it makes a lot more sense. I guess you could say, I learned something today.
Old Feb 24, 2011 | 06:17 AM
That's also how it maintains pressure with the engine off. If the fuel pressure regulator were not after the rail, all the pressure in the rail could just release through the return into the tank and it'd take forever to start the car (and for that matter, hoov, I think you're mistaken - I don't think a car would run if the FPR weren't after the rail to maintain pressure). But when the engine is off, the FPR closes, keeping all the pressure in the rail.
Old Feb 24, 2011 | 11:27 PM
sidneyam's Avatar
Haha thanks guys, a while ago when I had it at a shop they said the FPR hose was leaking fuel. So I just follow the fuel filter line eh?
Old Feb 24, 2011 | 11:30 PM
sidneyam's Avatar
Also do you guys know if I have to remove anything in order to et to the FPR?
Old Feb 25, 2011 | 06:29 AM
Just look for this. It's on the back of the plenum and there are only two fuel components there - damper and regulator. Link below is what you're looking for. But seriously, this entire thread is a joke - follow the fuel lines until you find the leak, don't just go replacing ****. And nothing needs to be removed to access the FPR.
http://www.courtesyparts.com/22670m-...tml?cPath=882&
PS hoov is probably right about it being the line that connects the rails... if you don't find a definitive leak, take it to a reputable Z shop, because you won't be able to handle a plenum pull to replace that one, yet.
Nissan/Datsun
Jan 7, 2015 06:15 PM
davidjoe007
Jan 31, 2011 11:08 PM
mrprofile
Jun 25, 2010 11:23 PM
Carl's Z
Feb 3, 2007 01:06 PM
Rbolz
Jun 5, 2003 05:59 PM
