Just bought a wrecked 300zxtt
Old Nov 14, 2010 | 01:31 PM
Dgk910's Avatar
alright i have already made posts here but i bought a 94 300zxtt for a parts car. The engine is suppose to be from z1 motorsports and it tries to fire but it won't crank. there was a broken sensor on the timing belt cover that i took off my 96 300zxtt and tried to see if the car would crank and it still would not start. I believe that it is not getting spark but i could be wrong. I did pull the coil pack out and spark plug out and tried to ground it while i had my grandfather turn the key and i couldn't see it spark at all. If anyone has any suggestions i would appreciate it.
Old Nov 14, 2010 | 01:38 PM
fallow the diagnostic procedures in the FSM.
Old Nov 14, 2010 | 01:46 PM
Dgk910's Avatar
the sensor is on the left side of the engine looking at it from the front. The exact opposite of the crank angle sensor i believe. Anyone know if the 96 to 94 model sensor would matter.
Old Nov 14, 2010 | 01:48 PM
Old Nov 14, 2010 | 01:49 PM
Dgk910's Avatar
alright. well where is the diagnostic section under?
Old Nov 14, 2010 | 01:59 PM
Dgk910's Avatar
nevermind went to a different site and found it under general information. thanks though
Old Nov 14, 2010 | 02:17 PM
BlueKitsune's Avatar
Intrawebz Wizard
Hoov your an ***.
Are you talking about the PTU? The early metal ones are known to fail
Old Nov 14, 2010 | 02:19 PM
Hoov your an ***.
Why, the FSM has an almost fool proof procedure for diagnosing **** like this.
Old Nov 14, 2010 | 02:22 PM
Intrawebz Wizard
I know but from what I read he was asking for the name of the part. Wouldn't hurt to tell him the name and common issues with that thing.
Old Nov 14, 2010 | 02:32 PM
Dgk910's Avatar
no its not metal its plastic and it has to connectors one on each side. It has a metal backing that is connected to the timing belt cover by four bolts.
Old Nov 14, 2010 | 03:03 PM
Dgk910's Avatar
yeah i found it on the internet. It is the power transistor unit. I believe the 96 model one should work for the 94 model engine.
Old Nov 15, 2010 | 09:29 AM
Dgk910's Avatar
Ran a self diagnostic test on it and got code number 55.
Old Nov 15, 2010 | 11:57 AM
domsgarage's Avatar
Tough Guy
Could be a long shot, but also check the fusible links as well.
Ive blown one or two before.
85_300zxt
Jan 18, 2008 07:05 PM
gabrielzzz
Jan 16, 2006 10:31 AM
VG30DETTZ32
Jun 9, 2003 11:28 AM
SunTadZ
Feb 14, 2002 02:15 PM
