how to fix a wobbly shifter?
Old Dec 21, 2013 | 11:11 PM
sac300zx's Avatar
so my 300zx is manual and the shift **** is really loose and wobbly in any gear..
need help on how to fix it this issue.
Old Dec 22, 2013 | 06:44 AM
KSpakes87's Avatar
A couple things to check. Remove the remove the radio panel and radio. Then remove the shifter panel. The shifter will come out with the panel also.
Next check that the plate that holds the shifter still is not loose. I had the rubber dampened dry rot and break one time. Made the shifter fall down. If that is ok then remove this metal plate and check the single nut and bold holding the shifter to the shift linkage. Then check the shift linkage for damage and IIRC it has two bushings toward the transmission.
CrazyLotusTT
Nov 17, 2015 07:45 AM
joselitopr
Oct 20, 2014 07:35 PM
kevtt
Mar 11, 2006 05:37 PM
bluesman1958
May 3, 2004 08:25 PM
CrazyLotusTT
Aug 10, 2002 10:37 PM
