HELP!!! z32 wont go in reverse after transmission change
well today I changed an automatic transmission in a 1990 z32 the used automatic with 90K miles i got from z32 2+2, as i put the auto tranny from 2+2 into a 2 seater everything seems to be working except that it goes forward in NEUTRAL, drive and 2 and 1st but wont got into reverse anywhere even when i try to push it i had no problems replacing the transmission everything seemed to be fine but it wont go in reverse is it my linkage or the used transmission i got might be bad please help :(
Adjust the linkage. If that doesn't fix it then pull and test the solenoids.
ok thanks mancan you give specific detail on how to test those tranny solenoids?
ok i tried to adjust the shift linkage but that didn't do crap so i disconnected the shift rod started the engine lifted the rear up got under the car shifted into reverse the wheels spun forward and then stopped :022: help....
Check the FSM for linkage adjustment, did you pull the linkage and shift the trans into gear by hand?
Originally Posted by hoov100
(Post 303874)
