Help!!!
Old May 1, 2009 | 01:03 PM
BobbySurfer's Avatar
Help!!!
Heres my problem, i have a 91' Z32 n/a
I all of a sudden started loosing horsepower, my exhaust has holes in it but that was like that when i bought it, so i don't think thats the reason. it also sounds a little weak on startup and after startup until its warmed up it idles around the 500 range when it used to idle around the 8-9 hundred range, and when i try to get on it rpm rises correctly but the engine doesn't sound its happiest louder than usual, i'm not a moron i've tried a few things the oil is fine just changed not long ago, i've changed the fuel filter, everything fluid wise seems fine, but i'm definately loosing horsepower. i wanna lean towards a fuel problem, i thought maybe bad gas, but i'm starting to think its more than that. if anyone can give me some advice it'd be much appreciated.
Old May 1, 2009 | 03:35 PM
DropTopTwin's Avatar
Maybe the alt or alt belt?
Old May 1, 2009 | 05:07 PM
KasbeKZ's Avatar
Pr0n Addict
gas won't go bad for around a year usually. a little less sometimes, but it's probably not your problem. are you getting any shaking or a very putsy exhaust sounds? do a balance test (pulling each coil pack individually and seeing if one doesn't make the idle go down. they should each make the idle go down. if one doesn't then that cylinder isn't firing) and see if you have a dead cylinder.
Old May 1, 2009 | 08:31 PM
second the test ^^^^ might have a bum coil pack/ spark plug/ injector. or just a bad connection even.
Old May 2, 2009 | 06:47 PM
rtmorgan's Avatar
Obsessive Craigslist Disorder
could be a faulty temp sensor too keeping you on a closed loop fuel map just a thought
Old May 4, 2009 | 05:40 AM
Hey
I appreciate the input i'll try the balance test first see where that gets me, thanks.
Old May 6, 2009 | 12:46 PM
Here is what i found
Ok. i pulled the ignition coils and found that the forward left and right i think its the one and two cylinders aren't working, i'm assuming those coil packs are failed, but why would they both stop working at one time???
Old May 6, 2009 | 12:58 PM
don't assume figure it out! unplug and remove the coil pack, stick a not used spark plug in it start the car round the plug and see if they spark. more likely the injector/s are dead compared to the coil pack
Old May 13, 2009 | 06:07 PM
dreamz90tt's Avatar
Have you pulled codes?
